Old 01-08-2014, 02:38 AM   #1
MotorHead Lon
MotorHead Lon's Avatar
6.5" rally and 3" lowering spindles
On my 84 GMC I have 3" spindles and 6.5" rallys. I've modified the lower control arm, by removing the lip. My wheels still rub. Does anyone else have this combo and made it work or do I need to move up to a 7" rally or do I need to trim the control arm back a little mroe.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 01-08-2014, 11:51 AM   #2
Jonboy
Slots go on anything!
Re: 6.5" rally and 3" lowering spindles
I ran that combo on my old '74. You probably just need to trim the arms a little more.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-08-2014, 02:48 PM   #3
MotorHead Lon
Figured out where I was rubbing. From the shaved wheel weight I can tell I hit the weight. So I'll rebalance the wheels and use stick on weights.
