Old 01-08-2014, 11:48 AM   #1
TheBlueBomber
TheBlueBomber's Avatar
How to know if your Rochester Quadrajet is worth rebuilding
Looking for information identifying Quadrajet's and rebuilding them.
This is the one on my 80-82 305 in my '79. A friend of mine said that you cannot rebuild the carb if gas is coming out of the plunger area. Also, was this originally electronically set up? The manual choke wasn't hooked up when I bought it.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-08-2014, 01:17 PM   #2
geezer#99
geezer#99's Avatar
Re: How to know if your Rochester Quadrajet is worth rebuilding
They're all rebuildable. Usually when they leak outta the accelerator pump stem it's from a flooding condition.
Here's some links to rebuild and identify them.
http://www.crankshaftcoalition.com/w...#Trouble_spots
http://www.digitalcorvettes.com/foru...ad.php?t=88376
And a parts source.
http://quadrajetparts.com/
Old 01-08-2014, 01:48 PM   #3
bnoon
One of the main reasons to rebuild a carb is if it's leaking from the accelerator pump plunger area. That means the pump is leaking fuel instead of pushing it into the engine when you first step on the gas which will cause a stumble on acceleration.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-09-2014, 11:22 AM   #4
TheBlueBomber
Thanks for the links
As for the stumble... sounds about right with what I was having, that along with bogging down on the trails/no acceleration rpms... then again its a 305.
Austin
Old 01-09-2014, 01:36 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
They are all worth rebuilding
http://cliffshighperformance.com/index.html
Malo83 is offline   Reply With Quote
Old 01-09-2014, 02:18 PM   #6
TheBlueBomber
When I first bought the truck, there were no in line fuel filters for the carburetor and the fuel filter at the front of the carb was removed. Not good.
Looking for a good rebuild kit and I think Im going to look at cliffs high performance kits a little closer.
Austin
Old 01-09-2014, 03:39 PM   #7
cool68
unless you are good at rebuilds, might want to look around for a local carburetor rebuild shop. got my done for $250 by a shop that specializes in old carbs . found worn bushings, etc that would not be noticed with me doing a rebuild myself.
cool68 is offline   Reply With Quote
Old 01-09-2014, 10:28 PM   #8
TheBlueBomber
The way I look at it, you've gotta start somewhere. I also have a second Quadrajet laying around so if I fail then I will have that... but I'm not going to fail.
Austin
Old 01-09-2014, 11:58 PM   #9
86swb
Born a Chevy Man
86swb's Avatar
Is the second Quadrajet a good one? If so why not just install it? Then you could also play with the one that needs rebuilt. MO
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 01-10-2014, 03:05 AM   #10
TheBlueBomber
The second one is from a mid 80's model with an electronic choke setup. I'll have to look and see what it is exactly. The one on the 305 has been converted to a manual choke (which the PO disconnected) and it looks to be a vacuum/heat setup originally.
Everything is all chopped up in there so I need to find out exactly what I have and determine if I want to go the electronic choke setup or not. What do you guys have?
Austin
Old 01-10-2014, 07:51 AM   #11
sean1969c10
sean1969c10's Avatar
The electric choke is easy and the most adaptable in terms of manifold swapping. The carb in your pictures is not an electronic feedback carb. Get Cliff Ruggles book on the Quadrajet and you won't have any trouble rebuilding that Quad!!!
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 01-10-2014, 07:05 PM   #12
swissarmychainsaw
Originally Posted by thebluebomber View Post
<snip>... But i'm not going to fail.
that's how it's done! Bam!
swissarmychainsaw is offline   Reply With Quote
Old 01-10-2014, 08:57 PM   #13
TheBlueBomber
A good friend of mine keeps insisting that edelbrock is the way to go and although its an easier carb to work on, from what ive read I believe the quadrajet will do me just fine for my purposes.
I know its not going to be easy especially since I've never even opened up a carburetor before but there is plenty of knowledge here and on other websites that I'm sure will help me.
Austin
Old 01-10-2014, 10:35 PM   #14
geezer#99
geezer#99's Avatar
Here's another good link for you.
http://www.vetteprojects.com/kstyer/quadrajet.htm
Old 01-13-2014, 11:56 AM   #15
jarero
I'm not sure what your application is but on a stock or mild motor that carb is just fine. I am not that impressed with any other edelbrocks that I have run in the past. Not that they were bad, just not much better than the quadrajet so I say go for the rebuild!
65' GMC Short Step
jarero is offline   Reply With Quote
Old 01-14-2014, 05:25 PM   #16
TheBlueBomber
The application is for a stock 305 but will end up for a stock/mild 350. I just need to find one now.
Austin
Old 01-14-2014, 05:33 PM   #17
67swb72klb
67swb72klb's Avatar
check out utube for some videos if you haven't yet just to see what you are in for
they are not that bad to do really
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-14-2014, 06:06 PM   #18
TheBlueBomber
Thats the reason I wanted some input from here, I was watching some videos last week and I thought I would go ahead and do it. Got the weekend off and I'm going to try and start working my M/T valve covers. If I get a chance to Ill stop at the book store and see what they have.
Austin
