Wanting to do an LS1/T56 swap into my '71 truck. It's a 350/350 combo so I'm worried about the trans fitting under the cab considering that I don't have a high hump cab. What could be done to make it fit, fab work, possibly a body lift?
Also, any idea what the clutch pedal setup will look like and what I'll have to change to fit all that stuff in the engine bay? |
Re: LS1/T56 swap question
You could always cut out the floor and install a high hump if you need the room. Mine actually fit however it is very very tight.
I did the install about 8 or 9 years ago back before everybody was doing it. I built my own mounts so I would say the mounts you choose will play a role in where it all will sit. I did start originally with a 4l60e tranny so I built it around that at the time. The new T56 made it close.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Fabricate till you "puke"
Go for the high hump, from a 6 cyl truck....you will find it to be a tad longer, & this may help with the shifter placement on the T-56 ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
