Old 01-08-2014, 04:33 PM   #1
400sbctruck
Help-Camshaft selection!
Ok, engine is a 400, 5.7 rod with aluminum 64cc heads, 10:1 with dish hypereutectics...Heads port matched, smoothed runners, bowl blend, all the way.
Retro-roller
Looking for something daily driver, good idle and broad torque curve. Hoping to see 400hp, idea here is more head, less cam and good street driveability.
400sbctruck is offline   Reply With Quote
Old 01-08-2014, 07:30 PM   #2
Jake Wade
Jake Wade's Avatar
Re: Help-Camshaft selection!
This going in a square? What rear axle ratio? What transmission? Which aluminum heads? Rear tire diameter? I like your vision on this build, give some more info and will tell you what I think.
Jake Wade is offline   Reply With Quote
Old 01-08-2014, 08:03 PM   #3
400sbctruck
Heads are summit brand casting, non vortec, performer rpm intake.
In the end 3.42 or 3.5 gear.
Tire size stock 96-98
Trans, 4l60 mild converter. You know, a SlEEPER!!!
Must apologize for posting this in this section/figured i may see some 400 fans here, truck will be 96-98 SWB.
Havent purchased any lifters yet, any road-worthy budget reccomendations appreciated.
Also, i have yet to polish chambers etc, so compression can be tweaked...
Originally Posted by Jake Wade View Post
This going in a square? What rear axle ratio? What transmission? Which aluminum heads? Rear tie diameter? I like your vision on this build, give some more info and will tell you what I think.
Old 01-08-2014, 08:20 PM   #4
Jake Wade
Jake Wade's Avatar
I take it your running a carb?
Old 01-08-2014, 08:50 PM   #5
Jake Wade
Jake Wade's Avatar
The 400 makes awesome torque. The larger cubes eat up camshaft and what is pretty hot in a 350 is fairly mild in a 400.
For the info provided I would run around a 272 advertised intake duration on a 110 LSA. Here is a Howards cam that should work well:
http://www.summitracing.com/parts/hr...make/chevrolet
Fairly smooth idle with a little exhaust note in a 400. Should provide strong low end and mid range but play out around 5500-5600. Will work good with the 3.42 gears and cruise well at overdrive RPM.
Brodix used to provide Summit with the IK line of heads, just under the Summit name, I assume they still do. They are good heads!
I run this through a DCR calculator with the above mentioned cam and come up with an 8.16 which is what you want to shoot for running pump gas.
A larger camshaft would be in order for a HOT street truck. When you say "good idle" "daily driver" "broad torque curve" I think this cam or one along these lines is what you want and should fit the bill.
Old 01-08-2014, 10:49 PM   #6
400sbctruck
Ill look into howards. Will that work well with injection?
Plan is this:
Yank vortec out, use crank trigger& dist substitute flex fuel injectors(32lbs) for the stockers...
Hopefully wind up with benefits of injection and maybe see 16-17 mpg? Letting computer control 4l60 and timing.
Im in the part gathering stage, tearin ebay and salvage yards apart.
Lots of 'fun' staring me in the face:
Setting up perf rpm with injectors, locating roller timing cover with crank sensor mount provisions etc. milling adapter plate for vortec throttle body to intake lol.
Luckily i can do most machining myself, aside from a line hone if needed, which i doubt.
Old 01-09-2014, 07:42 AM   #7
Jake Wade
Jake Wade's Avatar
I assumed you were running a carb and a 4L60, not the 4L60E and factory fuel injection.
