Boss 338 Wheels hub clearance
Has the clearing issues with the front center hub been fixed?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Boss 338 Wheels hub clearance
no.
thanks
Do you know how do guys get them to work?
http://67-72chevytrucks.com/vboard/s...d.php?t=537240
New guys,... you need to start reading. There is tons of info here about this issue. Use Google for your search. This is old news. Going on 5 years.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-13-2014 at 01:51 PM. |
Old member
Grind the end of the hub down with a flapper wheel. Takes about 20 minutes to do both.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
thanks
