Old 01-09-2014, 12:35 AM   #1
wahl4m
98c-20 -hard to put in gear ?
sometimes after starting truck -98 c-20-2500-350-auto - it is hard to put in gear ? have to pump brakes or shimmy column around shifter area ? something getting loose ? or ??
wahl4m is offline   Reply With Quote
Old 01-09-2014, 06:05 PM   #2
mountie
mountie's Avatar
Re: 98c-20 -hard to put in gear ?
Linkage
mountie is offline   Reply With Quote
Old 01-10-2014, 08:22 PM   #3
Orangette
Sounds like it needs a new shift cable.
FYI, no such thing as a C20 in 1998, it is a C2500.
Josh
1978 RCLB K20, Built 400 SBC, SM465, Lifted
1994 RCSB Silverado, 375HP 350, TH350, 4/6, Toy
Orangette is offline   Reply With Quote
Old 01-11-2014, 08:07 AM   #4
speedygonzales
speedygonzales's Avatar
Disconnect the linkage at the tranny. Then move the shifter and then move the tranny linkage by hand. That will tell you if the tranny or column or linkage is the problem.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-11-2014, 08:12 AM   #5
Orangette
They don't have a linkage, its a cable that runs down the column, and under the carpert, then goes through a rubber grommet to the trans.
It is common for the cable to seize.
http://www.rockauto.com/catalog/rafr...rtnum=15037353
Josh
