Old 01-09-2014, 09:54 AM   #1
ncr8rfan
1965 Chevy door window issues....
Does anyone know where to see some pictures or diagrams on how to remove the interior of door so I can repair a window issue? My window will not roll all the way up. I also need to replace some worn felt, and repair the vent window. Just wasn't sure where to start or how to remove everything properly without creating more work.
ncr8rfan is offline   Reply With Quote
Old 01-09-2014, 02:35 PM   #2
1966shortwide
Re: 1965 Chevy door window issues....
I am thinking sharp's 40 has a detailed picture post in this forum ,just click on his user name and it will show,all his post's.
1966shortwide is offline   Reply With Quote
Old 01-09-2014, 02:42 PM   #3
Sharps40
I think I have one broken out. I'll check in 10 and either link it or post the pertinate data below.
Sharps40 is offline   Reply With Quote
Old 01-09-2014, 02:53 PM   #4
Sharps40
This one is up in the FAQ section now with another good one that I read before doing my install.
See post 9 in the link for and update on the quality of the LMC parts I ordered. I'd rate them marginally acceptable.
Prolly worth some more investigation of quality and longevity before you order the parts. I'm not happy with the oversize fit of the vent window rubber nor the fact that felts leave tar stains on the glass with each trip up and down. The window channel felt and the vertical division channel are holding up perfect.
Perhaps Lynn Steele or another supplier? Don't know since I'd suspect much of the aftermarket auto trim is comeing from one or two Chinese makers and being distributed under many Brands by vendors across the country...i.e. might not be much in the way of choice where quality is concerned.
In any event, the LMC stuff is not as good for longevity and fit on my truck as factory but good enough that I don't expect to do the job again for several years.
Luck....
PS...gettin the door glass in and out is a damn wiggle festival.
http://67-72chevytrucks.com/vboard/s...d.php?t=599586
Old 01-09-2014, 04:26 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Ill second what Sharps40 said, I didnt find it all that difficult but it is sort of time consuming none the less. Go slow and treat each screw with WD or some kind of penetrating oil several times a day for a few days before you tackle the project, you want everything to come out nice and clean. I also have a round suction cup ( I think it is actually for floor tiles) that I attach to the glass and then it wont fall on me.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-09-2014, 04:40 PM   #6
ncr8rfan
Thanks for the info. I'm trying to get up enough nerve to knock this out. Just don't want to make it worse than it already is.....
Old 01-10-2014, 01:31 PM   #7
luvbowties
luvbowties's Avatar
Thumbs up Re: 1965 Chevy door window issues....
Just a thought: I'd surely look for/try adjustments on the glass before attempting a total removal. IIRC, I did this on one of our models (?) where the glass did not go all the way up at the back--it just needed tilting.
Sam
luvbowties is offline   Reply With Quote
Old 01-10-2014, 03:32 PM   #8
Clyde65
Clyde65's Avatar
If you were closer I would help if you provided the beers...It really isnt that hard but I do understand not doing it before could be a little intimidating.
Provide some pictures or a video of what your looking at, then maybe we all can lend a hand.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-10-2014, 03:33 PM   #9
Clyde65
Clyde65's Avatar
Clyde65
Rebuild of Clyde
support our troops!
Old 01-11-2014, 06:22 AM   #10
ncr8rfan
I have to work this morning. I will try to take picture this evening if I get in before too late.
