Old 01-09-2014, 01:16 PM   #1
grubbygreg
Rear axle problem
I need to remove my axles to replace the seals. When I removed the bolt/pin that retains the spider gear pin all I got was 3/8 in of threads and no pin. I have been told to pick it out but no success. Any suggestions?
grubbygreg is offline   Reply With Quote
Old 01-09-2014, 01:38 PM   #2
mmiddle
mmiddle's Avatar
Re: Rear axle problem
Well.... welcome to the club, this is a common problem that most get to enjoy.
First try lightly tapping the pin with a ball pien hammer then rotate the carrier and tap the other side. What happens is the spider axle over time gets twisted and binds the pin. You might get lucky and the pin just falls out.
Or less desirable on many levels is that you will have to drill out the pin. I aways tap on the spider axle first then remove the pin. (That is after of course the first time)
Good luck
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 01-09-2014, 02:41 PM   #3
Bigdav160
Bigdav160's Avatar
I've used this extractor tool extractor tool with sucess.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-09-2014, 03:12 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Bigdav160 View Post
I've used this extractor tool with sucess.
What Bigdave said... I fought mine for three days, trying every method I could find on the net, with no luck. Bought the extractor kit and had it out in 15 minutes.
LockDoc
Leon
Old 01-09-2014, 03:46 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
X3... the extractor kit is the only way to go.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-10-2014, 01:58 PM   #6
grubbygreg
After reading the comments about the extractor I ordered it. Thanks to all.
Old 01-16-2014, 08:59 AM   #7
grubbygreg
Got the the extractor still no success. Any plan B's out there?
Old 01-16-2014, 09:05 AM   #8
Grumpy old man
Grumpy old man's Avatar
When all else fails ...BFH ! it won't get the pin out but you'll feel a whole lot better after beating on it for awhile !
Grumpy old man is offline   Reply With Quote
