Need Some Advise...
I am expecting the last piece of wood for my bed tomorrow (it's complicated) and will need to stain and finish the wood ASAP after I receive the last board. What kind of clear have other people used? I was going to use Spar Varnish but have read it remains "soft" when it dries. I have considered urethane but I don't think there is any UV protection in it. I would like to spray on the finish because I'm not real good with a paint brush (I hate brush marks) and most clears have no instructions for spraying. I have considered using automotive clear but don't know if it is compatible with oil based wood stain. Any help would be appreciated.
If I posted this in the wrong place might a moderator please move it. Thanks! |
![]() Join Date: May 2010
Re: Need Some Advise...
I used Minwax Spar Urethane semi-gloss. It contains a high level of UV blockers. I brushed it on (5 coats, first 2 thinned) and it flowed after brushing so no brush marks were left. It also is expands and contracts with the wood. It does not seem soft to me. The wood almost looks as if it's sealed in plastic. Mar-K has lots of info and test results for many finishes.
Mar-K link: http://www.mar-k.com/installation_hints.aspx |
Moderator
![]() Join Date: Jun 2008
Hello ItsRandy!
Just to offer up a bit of knowledge from our FAQ section, this thread Wood Bed Finishing 101 may contain the advice that your are looking for. Good luck on your bed! -Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
