Old 01-09-2014, 11:28 PM   #1
68chvy
lowering my 68 swb
heyguys!
Icurrently have a stock frontend, when Ibought it, it came with 5 lug discbrake upfront. it has factory control arms and bolt in ball joints. I'm not 100% sure which route to.take.. I would love a mild/extreme Porterbuilt.. but that is kind of expensive for me right now. so I'm leaning towards dropspindles.. any input and ideas would be greatly appreciated!
68chvy is offline   Reply With Quote
Old 01-09-2014, 11:47 PM   #2
68chvy
Re: lowering my 68 swb
here's how she sits right now
Old 01-10-2014, 02:07 AM   #3
tinydb84
tinydb84's Avatar
Do porterbuilt stage one and add the drop member later as you can reuse most of the parts
David
Instagram: myfabguy
Old 01-10-2014, 08:34 AM   #4
68chvy
on a stage one, would.I change my ccontrol arms, and will that be using coil overs or how does it work.. thanks
Old 01-10-2014, 09:38 AM   #5
Bennett68C10
Bennett68C10's Avatar
If you go with bags the stage 1 would just be bags and cups and you reuse your stock control arms. I would still run a drop spindle anyway to get you that extra 2.5" drop. I would run the stage one front with the stage 2 basic rear kit that way you get there adjustable panhard bar, c-notches and shock crossmember. That with the stage one front would make for a nice kit. Very nice truck by the way.
Check out this thread, he did a great job showing the different stages of his Porterbuilt suspension.
http://67-72chevytrucks.com/vboard/s...d.php?t=609897
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-10-2014, 09:59 AM   #6
SCOTI
SCOTI's Avatar
For the 6x-87 C10's.... drop spindles before any other lowering mod. Then, if additional drop is desired, go from there. On 6x-70 trucks, swapping to disc brakes is 2nd behind the drop spindles just for the improved braking.
You need to determine how much drop you want. That helps determine which 'way to go'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2014, 12:08 PM   #7
68chvy
thanks..
question.. if I already have disc upfront on my 68.. What wouldl I order thedrop spindles for? a 70+?
Old 01-10-2014, 12:28 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 68chvy View Post
thanks..
your truck has been converted to disc brake. There are several methods used ranging from stock parts to aftermarket kits. You will need to determine what was used to order the correct era drop spindle.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-10-2014, 02:52 PM   #9
68chvy
this may sound.stupid to.some, but how would I know what I got on there? all I know that it is disc in.front 5lug.. control arms look stock due to.the steel controlarm bushings.. theupperballjoint is bolted in.. notsure if 68 came with bolt in.ball joints
Old 01-10-2014, 03:05 PM   #10
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
sorry to thread jack... but which wheels are those?
chevyguy_72 is offline   Reply With Quote
Old 01-10-2014, 06:47 PM   #11
68chvy
theyare Boyd coddington.. notsure what series.. camewithtruck 20s frontandrear
Old 01-10-2014, 07:23 PM   #12
68chvy
Wellthey had Boyd coddington centercaps
