Old 01-10-2014, 03:31 AM   #1
79GMCSierra
79GMCSierra's Avatar
79 GMC 4.1L 250 Cylinder Head Advise
Hi All,
After doing a through inspection of my new purchase I discovered the the cylinder head is cracked on the exhaust manifold that is part of the cylinder head.
I believe this head is known as an Integrated Head. Please correct me if I'm wrong.
Anyway I'd like to replace it with a Normal I6 head that has a separate Intake Manifold and Exhaust Header.
My little bit of research tells me that a 78 head might be what I'm looking for. Or as mentioned on another thread a 194 Head. More info on the 194 head would be greatly appreciated.
So what might be your recommendations, keeping in mind this is a California truck. Funny thing is... I just had it smog'd and it pasted with the cracked exhaust manifold.
79GMCSierra is offline   Reply With Quote
Old 01-10-2014, 07:25 AM   #2
79Betty
79Betty's Avatar
Re: 79 GMC 4.1L 250 Cylinder Head Advise
If it passed smog i would just weld the crack up. Can't do much with a vehicle after 1974? In cali.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 01-10-2014, 11:31 AM   #3
D13
D13's Avatar
You can swap to a non-integrated, you will need intake/exhaust/carb and the carb linkage may not work. Is yours a 1 barrel or 2 bbl carb (take off air cleaner lid, if carb top is round, 1bbl, rectangular, 2bb)? There are no factory 2 bbl non-integrated mainfolds, so you would need aftermarket intake and carb or go to factory 1bbl.
194 head has smaller combustion chambers for a little more compression, but has siamesed exhaust ports so headers don't work as well. All the other non-integral heads are about the same. late 292 have AIR plugs in them so if you have AIR you would need those.
Rebuilt (or at lest cleaned and checked) integral heads show up on ebay time to time for $250-300. That's about what it costs to have a normal head reqworked, before you get the carb, intake, and exhaust. Just make sure you get the right one, and expect to add new rockers / gaskets, etc.
Oh, and buy Leo Santucci's book, version 2. Lots of good info on L6 even though it's heavy on race prep.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-10-2014, 12:28 PM   #4
79GMCSierra
Yup that would work, or I may just replace it with a 79 remanufactured head. Thanks for your suggestion.
It's a 2-bbl. Just ordered Leo's book. Thanks for all your input.
Old 01-10-2014, 07:26 PM   #5
lilpoindexter
lilpoindexter's Avatar
My '78 California Truck has the crappy integrated head.
lilpoindexter is offline   Reply With Quote
Old 01-12-2014, 02:26 AM   #6
79GMCSierra
Talked with John from Autowerks today from Iowa and he said any I6 head can work from the 230 to the 292, but may need combustion chamber work. His machined & ported heads go for about $1,100... that's what I paid for the whole truck! Not sure if I'm ready for that. I'm going to keep a lookout for a non-inter-grated head. I'm thinking checking cylinder head gaskets to see what models they fit. Which may be a good clue where to look.
Old 01-12-2014, 02:51 AM   #7
79GMCSierra
I feel your pain! Guess I should have done more research before I pulled the trigger on my new guest in the side yard. Oh well I'm learning...
Old 01-12-2014, 09:54 PM   #8
beamn7
My 78 federal emissions C10 has the non-integrated head / 1bbl carb. Truck has been in the family since factory order and has 250K miles on her. Never been apart. Great engines! I would imagine you could swap it to a non-integrated and hope the smog guy is too young to even know what a L6 is but...........that's pushin your luck. I would try and find another integrated head even though they are problematic...
beamn7 is offline   Reply With Quote
Old 01-13-2014, 10:31 AM   #9
moregrip
moregrip's Avatar
I'm sort of hodgepodging a few trucks together to make one....long story short.....I started with an integrated head 250L6 motor and am now switching to a non integrated 194 head as a result of speaking with Tom Langdon........in a nut shell, he believed if the integrated head didn't already have a crack, it would soon would.
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-13-2014, 11:17 AM   #10
Warrens69GMC
Warrens69GMC's Avatar
I have a 331184 on a 250ci that I bought in a 1979 nova. You might want to look for that part # .
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-13-2014, 03:39 PM   #11
79GMCSierra
When I took it to the smog shop last week the young guy there couldn't figure out how to shift it. It's 3-sp on the floor. He keep putting it into reverse LOL!!
I see you live in California, and your 79 Chevy C10 non-intergated head passed smog I take it.
Does your engine have these items pictured below. The vacuum valve is attached to the detachable header, so I may be able to find a non-intergrated header with that smog valve. For some reason it rotated the pics when I uploaded them.
Yup like the the machine shop guy said "It's a mistake"
Thanks Warren I'll kook for that part number!
Thanks all! Jim
Old 01-13-2014, 04:52 PM   #12
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
When you get ready to remove the integrated head , Have an extra set of hands close . I weighed mine and it was 142 lbs .
powerdriver 1958 is offline   Reply With Quote
Old 01-13-2014, 05:41 PM   #13
79GMCSierra
YIPES!!! Good call!
Old 01-16-2014, 12:43 PM   #14
beamn7
Thanks all! Jim
Yep! It's actually a 78 but yes, it does have the EGR valve and the charcoal cannister you posted in your pics. Difference also though is that the non-integrated heads use a single exhaust outlet manifold whereas the integrated head on yours has the dual outlets. Having said that, you would also need some exhaust work if you were to change it over.
Mines a 3 spd also (back on the column again) and sometimes I think that's the best theft deterrent around. Nobody knows how to drive them anymore!
Old 01-16-2014, 02:59 PM   #15
79GMCSierra
Yup every time I've taken it somewhere for service I've had to coach them on how to shift it!
