Old 01-10-2014, 10:09 AM   #1
KatFish
96 Tahoe with 98 Trans/T-case ?
Im trying to find out if I can swap the plugs out from my 98 Tahoe to the 96 and the 4wd work?
KatFish is offline   Reply With Quote
Old 01-10-2014, 09:36 PM   #2
ryanroo
ryanroo's Avatar
Re: 96 Tahoe with 98 Trans/T-case ?
I'm not sure if there is any diffence in wiring harnesses but the trans is the same, and as long as the t-case isnt and an auto shift model going in place of a non auto shift, that should be the same as well. they are both OBD2 era trucks so any controls coming from the ECM would be executed the same in either truck. this is assuming they are both half ton based trucks.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-13-2014, 11:10 AM   #3
KatFish
yea the 98 had the auto 4wd option
Old 01-15-2014, 04:48 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
The transmissions are different. 97 was a split year. Late 97 and newer have a one piece bellhousing that is removable from the transmission. Early 97 and earlier have a integral bellhousing that is not removable and a torque converter cover that is removable. There may be some electrical differences in the transmissions too.
All that is for 4l60e. The standard transmission in tahoes and half ton trucks.
95 S_Trucker is offline   Reply With Quote
Old 01-15-2014, 10:09 PM   #5
arkracing
Weekend Warrior
Agreed. There are electrical differances inside the trans as well. You really have to be careful with these years as most of them are considered "one year only". I had a '96 truck and ended up having my trans guy make one out of the existing '96 trans and a '94 trans that I had.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
