Old 01-10-2014, 02:33 PM   #1
VWNate1
VWNate1's Avatar
Question '69 Grille On '72 ?
Does this require changing the core support ? .
Or just the grille complete ? .
I know you alls will know this .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 01-10-2014, 03:31 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: '69 Grille On '72 ?
I THINK all you'll need is the complete grille and 71/72 center support (the one the hood latch is attached to). Core support is the same. Perhaps someone else can verify.
FirstOwner69 is offline   Reply With Quote
Old 01-10-2014, 09:01 PM   #3
VWNate1
VWNate1's Avatar
Thumbs up Re: '69 Grille On '72 ?
Thank you Sir ! .
I'll wait for more replies before taking things apart .
-Nate
Geezer
Old 01-10-2014, 09:36 PM   #4
jdalexa84
I believe that it is the same mount. I know that the hood is the same. I believe ask you need is the inner and outer grill
jdalexa84 is offline   Reply With Quote
Old 01-10-2014, 11:03 PM   #5
FirstOwner69
LMC catalog links. These should help determine what's needed. For example:
69/70 grille support (#8): http://www.lmctruck.com/icatalog/cb/full.aspx?Page=73
71/72 grille support (#7):
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=74
Looks like the hood latches are different also. Surprises me.
http://www.lmctruck.com/icatalog/CB/full.aspx?page=22
Old 01-10-2014, 11:07 PM   #6
sduckworth13
sduckworth13's Avatar
The grills are interchangeable, pretty simple to change out.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-10-2014, 11:43 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
To make it look right you need to change the 72 bumper and brackets for 67-70 ones, unless you want two sets of turn signals. Btw i have both for $100 shipped.
WIDESIDE72 is offline   Reply With Quote
Old 01-11-2014, 12:22 AM   #8
70LonghornCST
Moderator
70LonghornCST's Avatar
Good information here. Have fun with your conversion!
-Richard
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-11-2014, 12:55 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
All you need to do to swap a 69-70 grill into a 71-72 or vice versa is the grill and corresponding center bracket. Core supports are the same. 67-70 bumpers do not have turn signal holes. 71-72 bumpers do. 67-70 bumper brackets are the same, but different than 71/72.
I swapped a 71/72 grill and bumper onto a 70 that was wrecked. Not only because i like the look better, but i already had the parts.
Old 01-11-2014, 12:37 PM   #10
VWNate1
VWNate1's Avatar
Thumbs up Re : '69 Grille On '72 ?
THANX ! I knew I could depend on you alls to sort this out for me .
-Nate
Geezer
