![]() Join Date: Jan 2014
Picked up my first C10
Just picked up my first C10. It's rough but runs decent. It has 396 badges on the side. I cannot read the tag on glovebox do to someone covering it in masking tape years ago. Having a really hard time removing the tape without destroying the sticker. I will post more pictures this weekend.
![]() Join Date: Mar 2012
Re: Picked up my first C10
Looks good and solid from this picture
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Nov 2013
wet the tape and may break apart with rubbing
Very nice .
Nice find and welcome to the board!
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
I need to replace the metal bed floor. I see that the bed floor is bolted on the sides and the front of the bed. But how is attached on the rear? I have been looking at this truck for seven years before the owner decided to sell it to me.
Florida Edition
![]() ![]() Join Date: Oct 2010
Welcome from Florida also.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: May 2010
Nice truck.
![]() Join Date: May 2013
Nice find
Welcome to the Forum and it's nice you brought a good truck and pic's.
Good lookin' rig you got there!
nice truck
#13 |
Nice pickup! I live about 50 miles from you, over in Winnsboro. Good luck with your new project.
#14 |
![]() Join Date: Jul 2010
Looks like a solid truck. Welcome to the forum.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#15 |
Thanks!! I went ahead and threw a different wheels and tires on it. Need to find some center caps.
#16 |
Moderator
![]() Join Date: Jun 2008
Welcome! Very nice project. I can't wait to see it as you get it to where you want.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#17 |
Front end shot
#18 |
![]() Join Date: Jan 2011
Nice looking truck ! Welcome to the board from TN.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#19 |
awesome truck man.
#20 |
nice truck!!! on the bed floor i'm doing the same... replacing the floor. they are like 6 bolts holding the bed to the frame. youll wind up cutting them if you'e luck is anything like mine but it's not a big deal to replace. good luck!!!
#21 |
![]() Join Date: Feb 2011
Very nice truck, and a big block to I like it. On the tape over the spid. You might try taking the lid off and putting it in the freezer, some adhesives will brittle and let go. I would not use water.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
#22 |
Got my center caps on and painted the wheels.
#23 | |
The Older Generation
The rear has a small spot weld on each side by the stake pocket support. Cut or grind the spot welds. Everything else is bolted. LockDoc
#24 |
Nice truck, Great find when you go to take the bedside off the floor, a little tip, don't loosen the bedside attaching bolts. Tighten them that way they will snap right off so easy with very little effort and resistance. There are several places to find a new steel floor out there now, of course it could also be changed over to a wood floor bed as well. Love them big blocks, as long as you don't have to feed them. Jim
#25 |
Tot Roddin'
I dig it!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
