Old 01-10-2014, 03:16 PM   #1
bigmac73
bigmac73's Avatar
tranny
will a TH350 bolt up to a BBC , just thinking about doing a swap to a BBC, I am bored at work so i am making a list of all the swap items, cost ect ect
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-10-2014, 04:09 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: tranny
Yes, assuming its a normal GM pattern transmission and not a Buick, Olds, Pontiac transmission.
Old 01-10-2014, 04:23 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: tranny
TH350's aren't really built to handle the TQ of a BBC. So just make sure you have one that will handle 400+ ft lbs of TQ and you should be good.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
