01-11-2014, 03:11 AM | #1 |
power steering box bolt size help!!!!
Does anyone know what the size and pitch of the mounting bolts are for a power steering box off a 1985 c10?
01-11-2014, 03:16 AM | #2 |
60-66 Nut
Re: power steering box bolt size help!!!!
The pickup power steering box bolts are 7/16"-14
01-11-2014, 03:26 AM | #3 |
Thats for the metric box? I tried some 10mm bolts and they where not it.
01-11-2014, 03:36 AM | #4 |
60-66 Nut
It's been a long time since I have dealt with a steering box newer than '80, but as far as I know they should be 7/16"-14, just the fittings are Metric. No one has ever comlained about the bolts I supply with my steering box adapter plate. I can check a box at the shop tomorrow. If they do happen to be Metric, they are probably M12-1.25 or 11mm (don't remember the pitch).
01-11-2014, 03:40 AM | #5 |
if you don't mind checking that would really help. Thanks again
01-11-2014, 07:04 AM | #6 |
They are 7/16-14. Not to butt in but I had a box laying on the bench.
It's not uncommon for those "cross-over to metric" years ( about 1979 thru 1986)to have both types of fasteners. even up into the '90's on the engines, still use mostly SAE threads on the blocks. |
01-11-2014, 11:04 AM | #7 |
Thanks guy for your help!!!!!!!!!!
01-12-2014, 12:21 AM | #8 |
60-66 Nut
Yep I also verified they are 7/16-14
