Old 01-11-2014, 11:14 AM   #1
plumbers crack
plumbers crack's Avatar
Interior year?
The interior in my crew cab was swapped out for suburban interior. I have the brothers and LMC catalogs but I can't find the door panels or the pockets in any of them. Can someone id the year? Is the color gray or charcoal?
I can get a pic of the back of the panel if that will help.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
Old 01-11-2014, 11:57 AM   #2
Irish1941
Irish1941's Avatar
Re: Interior year?
Your interior is from an '89-91 and what GM called dark gray but it's not really dark. Anything marked as gray should work. And only Subs got the velcro map pockets.
Are you missing pieces?
Irish1941 is offline   Reply With Quote
Old 01-11-2014, 12:22 PM   #3
plumbers crack
Re: Interior year?
Thank you sir. A few bits are missing and some of the chrome is in tough shape and there are some stains in the fabric that might not come out. I still have to clean it up but I want to replace the bits that don't clean up. Also looking for a set of silver inserts for the front door panels to match the dash.
I also need A pillar, over the doors, across the windshield trim, rear seat belts and gray rear seat cover to finish it off. Probably forgetting a few bits but just needed to what years I need parts from.
Old 01-11-2014, 12:27 PM   #4
plumbers crack
Re: Interior year?
I'd also like a spare set of map pockets just in case they start to fall apart.
Old 01-13-2014, 10:18 AM   #5
carboncrew
carboncrew's Avatar
Re: Interior year?
you may be able to find the door inserts on ebay or vintage parts warehouse. You could also buy the 80's style door insert and carpet insert, it will fit across your door panel. You could also buy an aluminum door insert (aftermarket repop) and peal the aluminum trim off and cut it to fit your shorter 89-91 door inserts. Hope that helps.
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 01-23-2014, 06:46 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Interior year?
my 87 had those ,sliver inserts,can't seem to find them right now
and they would fit in the later panels(I'm using 87 left 89 right)
truck looks good,yup later style seats n doors panels like my 89s
87 didn't have velcro,or sectioned seats
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
