Old 01-11-2014, 06:03 PM   #1
kd360
Air conditioning from 02 in my 72
I recently purchased a 2002 silverado to do a 5.3 swap, since I already have it I was thinking of using the factory a/c system out of it. Has anyone tried this ? It looks like my firewall will have to be modified in order to make it work.
kd360 is offline   Reply With Quote
Old 01-11-2014, 06:35 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Air conditioning from 02 in my 72
Is there room under the dash? Since most of the stuff is inside the trucks now, the inside cases are huge in comparison to ours.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-11-2014, 10:46 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I used everything in the cab and put all new components under the hood. Replaced the evaporator, lines, put in a Sanden compressor.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-12-2014, 02:20 AM   #4
kd360
It's a tight fit measurement wise but I think it will fit. It seems like part of the unit will be close to the wiper motor. Smitty, did you use the existing71 a/c unit on the firewall? My truck was not an a/c truck originally. Being that I am doing the 5.3 swap I am going to use the compressor that is on the engine now. I really did not want to spend the money on the vintage air kit or a similar kit if I could make this work.
Old 01-12-2014, 02:41 AM   #5
motorcritter
motorcritter's Avatar
Subscribed- going to do a LSx swap on a '68 GMC LWB. Debating whether to get driveline only or complete wrecked truck. I would love to use all new stuff for A/C.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 01-12-2014, 08:46 AM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Air conditioning from 02 in my 72
The orignal AC on the Ls motor is down at the bottom of the engine. You will have a heck of a time if you leave it there but there are opitions to put it up top.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-12-2014, 01:07 PM   #7
71meangreenc10
Yes,
The box is the original, but my cab is an ac cab. The guts in the box were changed to fit my compressor.
Smitty
71 C30 Wrecker
Old 01-12-2014, 06:24 PM   #8
68c10airstream
68c10airstream's Avatar
Hi kd360, I currently have my 5.3 swap out for engine work, and laying parts out for ac install. I used the organ donor 2001 mounts (down low out of the way) a trailblazer 5.3 compressor for down low on pass. side because the suction/discharge ports are in-line front to back and i refuse to notch my frame for the organ donor truck silverado compressor (suction/discharge ports are side by side left to right). I made my own motor mount brackets for the 2001 mounts. I refused aftermarket perches because they got in the way of headers/ low mount ac compressor. I will be using a 67-72 cab parts with a newer evap. I'm using clutch fan (don't need cooling fans), will be using cycling clutch orifice tube style. My pcm will see ac clutch request via low press. cycling switch on the accumulator. The beauty of all of this is this; no notched frame, no electric fans,ac system will be working just like the organ donor 2001, simple system mounted low out of the way. My only unresolved issue is ac bracket for the trailblazer will either need mods, or put 2 mounting bosses welded to side of oil pan. That,s it. Look at dirty dingo mount pics trying to do low ac mount and they are in the way. Look at perches up high on side of frame and headers hitting them. I don't like electric fans on the forward side of radiator getting rained on but it works. Additional electric considerations using fans but is dueable. Many car friends (nuts) say my engine bay looks like it came from gm. Perfect!!!. I hate chrome this and that, i just want it to work with oem sourced parts for many reasons. If you want pics there in the works. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 01-12-2014, 08:51 PM   #9
mmiddle
mmiddle's Avatar
Interested in this also.... I saved all the electrical and A/C stuff from the '99 doner.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 01-12-2014, 10:35 PM   #10
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
I crammed the 02 unit under the dash of my 72 in my Young Frankenstein build a couple of years ago. It WILL fit, but takes a good bit of work. Its all documented in my build thread.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 01-13-2014, 08:59 AM   #11
MARKDTN
There is a thread on putting a suburban on a late chassis that has info on this-see above. Bottom line, it can be done but requires extensive firewall mods.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-14-2014, 02:40 PM   #12
kd360
Thanks everyone, I have the a/c unit out of the donor truck, I am going away for business for the week so needless to say nothing will get done. Once I get back I am going to make a decision as far as what to do. It sounds like if I had a factory a/c truck I could have done it a bit easier. One way or the other it's getting air, I am tired of sweating in the summer.
Brian F., I bought the dirty dingo mounts and I am going that route too. It seems much easier and cleaner.
Old 01-14-2014, 03:57 PM   #13
67 chevelle
67 chevelle's Avatar
this is what I did for the compresor ,
http://67-72chevytrucks.com/vboard/s...24#post6240624
do a search , lots of options
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
