01-11-2014, 07:30 PM | #1 |
Low compression
Hi all. My 355 I've realized a ticking noise come out the exhaust. Sounds like an exhaust leak but coming out the pipe itself. So readjusted the valves and it was still doing it. I've narrowed it down to the #7 cyl because it keeps killing plugs. But in away I've never seen. The plug gets pretty lol like really clean. With a slick texture to it. Well, when I done the compression test it read back 60. Squirt a little oil on the hole and it came back 90-100. Rest have 160 to 170. Motor is around a year old. Still has soft seats and that head. Other side lost seat but happened suddenly. And none of these other signs came with it. It just happened. It's 68 327 double hump heads, flat tops which may put it 10-5 to 11. So all the builders have told me. I had been running a vp mix with it for awhile to give lead and that little more octane. But didn't last fill up and here we are. Awesome right? Thoughts? I give enough info?
01-11-2014, 07:35 PM | #2 |
Re: Low compression
Also. Even with this problem it still has loads of power. Blows the tires off still but it down a little.
01-11-2014, 07:44 PM | #3 | |
Re: Low compression
Check the lift on the valves of that cylinder, could be a cam lobe going flat, although oil down the cylinder shouldn't affect that? Maybe broken rings?
Leak-down test?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-11-2014, 08:00 PM | #4 |
Re: Low compression
The valve appears to be opening and closing all the way. How do you do a leak down test? Now, on the way back home a second ago which is right at 20 miles, the entire way I felt it slowing down more and more. Each red light idling worse and worse. Last one I had to pop it in neutral to keep it alive. Ticking noise getting more clear. I believe its the valve..
01-11-2014, 11:56 PM | #5 |
Re: Low compression
Usually when you add oil and the compression comes up it means rings. check the noise with a broom handle or dowel rod to locate the noise before tearing it down to fix
01-12-2014, 11:33 AM | #6 |
Re: Low compression
I wouldn't run any more than neccessary now. Leak down test and listen for any escaping air to tell if it's a valve or ring.
01-12-2014, 05:01 PM | #7 |
Re: Low compression
If the plug is coming out clean, that is no carbon or no oily residue, I would suspect that cylinder is getting moisture/coolant in it. Possible head gasket problem.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
01-12-2014, 08:31 PM | #8 |
Re: Low compression
Zeldman, I was thinking the same. I have it parked, gonna drive my 67 for now till I can fix it. Thanks guys!
01-12-2014, 08:41 PM | #9 | |
*** That's interesting ***
Re: Low compression
Either way, the news is not good. The bad compression needs to be investigated either way. It's probably time to pull the head.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-12-2014, 09:44 PM | #10 |
Re: Low compression
I vote cam wiping out. its the only thing that will get that much worse that fast
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-12-2014, 10:08 PM | #11 |
Re: Low compression
Its still firing, just 100 degrees off from the other cylinders from the header. And I wouldn't think cam just because the valve spring appears to still be opening and closing all the way. But who knows. Ima just pull it and go from there
01-12-2014, 10:45 PM | #12 |
Re: Low compression
Keep us posted. There are naysayers about today's oil and flat tappet cams. I'm trying to mentally keep track of those who have wiped cams to see if there is a real trend. If that's your problem, sorry about the misfortune.
01-13-2014, 01:11 AM | #13 |
Re: Low compression
I think it's a burnt or bent exhaust valve. That's why you hear it down the exhaust pipe. If you're lucky that #7 exhaust valve may just be too tight.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-13-2014, 07:22 PM | #14 |
Re: Low compression
Being here as long as I have I bet there has been a few hundred threads of oops new cam just wiped out and almost everytime it was an engine that either didn't have proper break in performed or either the correct oil or an additive wasn't used. Also been quite a few that only used a zinc additive on break in and then changed to regular oil to have it wipe out a few miles down the road.
01-13-2014, 09:35 PM | #15 |
Re: Low compression
The cams over a year old, at least 5k miles. We broke it in properly and no metal in the engine. So I'd say not. But I'll find out when I get around to tearing it down
01-14-2014, 12:19 PM | #16 |
Re: Low compression
No metal in the oil is a good sign!
01-14-2014, 05:40 PM | #17 | |
One of the First
Re: Low compression
Good Linky: http://www.4secondsflat.com/Spark_plug_reading.html
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 01-14-2014 at 05:49 PM. |
01-18-2014, 08:48 PM | #18 |
Re: Low compression
It is the valve. Pulled it out and yep. Everything else is fine. Me and a buddy got it out and heads off in a little over 2 hours. Taking our time trying not to make a mess and stay organized. Not bad.. We are getting pretty routine lol
