Old 01-11-2014, 10:03 PM   #1
ls1man
ls1man's Avatar
5.3 exhaust manifold in 47-54 ?
What type of exhaust manifold will work for ls engine in a 47-54 truck?
ls1man is offline   Reply With Quote
Old 01-11-2014, 10:43 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 5.3 exhaust manifold in 47-54 ?
Corvette Stainless steel sheet metal manifolds. first choice
A Cadillac CTS-V 6.2 L left and a 07 Trailblazer right last choice
Don't bother with GTO Camaro or a trailblazer SS left side.
Tru rams from Speedway look like they would work but they are pricey
dwcsr is offline   Reply With Quote
Old 01-12-2014, 12:55 AM   #3
Angryman117
Running C5 Vette manifolds and modified front exhaust in mine. Have the pics in my build thread.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 01-12-2014, 12:58 AM   #4
LEEVON
Moderator
LEEVON's Avatar
I've got Hooker LS block hugger shorties, fit nice. They dump center, have to make a tight radius to the rear other than that no issues.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-12-2014, 01:17 AM   #5
BlueJeep
BlueJeep's Avatar
I've got a 2003 Suburban manifold on the passenger side and a 2002 Camaro manifold on the driver's side, but I have an s10 frame too.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-12-2014, 09:13 AM   #6
solidaxel
solidaxel's Avatar
Thanks Dave for the info !!
Just bought some Camaro manifolds, should have read this first !!!!
Now I am looking for Corvette manifolds !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-12-2014, 10:22 AM   #7
ls1man
ls1man's Avatar
I have 3 sets of corvette manifolds both c5 and c6 neither will fit without touching, maybe i should raise the engine up a little more but in not sure what the maximum height can be. Also have mustang ii suspension so the steering shaft is a big problem to solve.
Old 01-12-2014, 10:27 AM   #8
solidaxel
solidaxel's Avatar
Can you take some pictures so I can see the difference.
I sure like the pic that Dave sent with his Corvette manifolds with the center collector
LS 3 4L70E
Old 01-12-2014, 10:44 AM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
The center collector corvette that are very short didn't fit. I would have had to notch the frame. The corvette that are long collector looked good but my engine mounts were is a non stock position so they didn't work for me. in picture B the center one looked like it would work the bottom one was a CTS-V and that dumped into the middle of the rail. it was fine on the other side.
C6 corvette didn't fit either they dump to far into the rail. LS1 LS6 5.7L 97-00 looked good but to pricey to buy to find out
Old 01-12-2014, 10:50 AM   #10
ls1man
ls1man's Avatar
I will post some pics after while.
Old 01-12-2014, 06:30 PM   #11
not2oldchevy
Early c5 on mine they fit perfect with no mods.
not2oldchevy is offline   Reply With Quote
Old 01-12-2014, 08:43 PM   #12
ls1man
ls1man's Avatar
heres a pic of the corvette manifolds i have.
Old 01-12-2014, 09:21 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
So none of those fit? You have a pile like I do. I have seen the first one on a AD truck with a 5.3 so that's why I said they should. How far in the frame does the engine sit?.
The picture below is a CTS-V on the left and a SS Trailblazer on the right. The problem with this setup is the CTS has a huge 3" opening and a bolt pattern that 4-5/8 center to center on the studs and the TBSS Manifold is 2.5 so I have some fabbing to do on it.
Old 01-13-2014, 07:41 PM   #14
not2oldchevy
The one you have on the left is what I have on mine with no issues.
Old 01-13-2014, 07:56 PM   #15
ls1man
ls1man's Avatar
How high is your balancer above your original crossmember? My engine may be to low.
Old 01-13-2014, 09:14 PM   #16
ls1man
ls1man's Avatar
The picture below i
The balancer is 1and 3/4 inch above the original crossmember.
