Old 01-11-2014, 10:57 PM   #1
kentrace
porterbuilt question
Should my C-notch brackets have holes for airbag bolts and air fitting or do I need to drill them. Looks like the fitting hole will cut through the edge of the bracket. Thanks for the help.
Basic stage 2 kit.
kentrace is offline   Reply With Quote
Old 01-11-2014, 11:21 PM   #2
MattPSU
MattPSU's Avatar
Re: porterbuilt question
I had to drill mine. If you don't already have a big step bit, pick one up. I got mine at Harbor Freight. My hole came so close to the edge that I just opened it up and made it more like a cut out rather than a hole. Good luck and have fun! - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 01-12-2014, 06:14 PM   #3
chevjayfsd
Project 7dos
chevjayfsd's Avatar
You'll need to cut and drill.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
