Old 07-18-2003, 09:45 PM   #1
kolectrkev
Angry Help!!!!! I can't get my manual hubs unlocked
Hey guy's,
I'm brand new to this forum and a new first time owner of a 71 chevy 4x4 custom camper. I need some help, the manual hubs won't unlock. Where do I go first?
Thanks,
Kevin
kolectrkev is offline   Reply With Quote
Old 07-18-2003, 09:57 PM   #2
sakohntr
sakohntr's Avatar
try this
jack up the front end and spin the tires and see if that helps. Sometimes they will not unlock with tension on them. I am assuming you have a 3/4 ton with spicer lockouts. "camper special". Make sure you have the transfer case in 2 HI also.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 07-18-2003, 10:00 PM   #3
kolectrkev
Thank's, I'll try it first thing in the morning and let you know.
Old 07-19-2003, 11:51 PM   #4
MJN
MJN's Avatar
Sometimes they turn after backing up and driving forward a couple feet just to release the tension on the hubs.
Old 07-20-2003, 12:09 PM   #5
kolectrkev
Thanks guys, I jacked it up and they freed right up.
Old 07-21-2003, 11:18 AM   #6
6869704X4
Sometimes I have to rock my truck back and forth to unlock the hubs if I haven't put the transfercase in 2wd. I just grab one of the lugs on the swampers and rock while Im unlocking.
Also if you stop in a turn you will have a hard time getting the xfer case out of 4wd. When your ready to take it out of 4wd you can slip the trans in neutral before you stop(in a straight line) and this should relieve the binding in the xfer case. The hubs should be easier to unlock then too.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 07-22-2003, 07:14 AM   #7
ZOOMY
unlocking
Block the wheels so the truck won't roll & put the trans & case in neutral. That also takes the tension off.
ZOOMY is offline   Reply With Quote
Old 07-22-2003, 05:26 PM   #8
kolectrkev
Thanks for all your help guy's. I jacked the front end up and they they freed right up.
Kevin
