Old 01-12-2014, 05:42 PM   #1
JIMINITWIN'72
To shave or Not to shave that's the question
I have a 72 C10 LWB and I am considering shaving the drip rail and welding the seam across the back at the top of the cab. Has anyone done this, I have heard that it drastically reduces the rigidity of the cab. Is this true? If it's doable any insights would be awesome. I am doing a resto-mod on the truck.
It is what it is, Cause it was what it was...
JIMINITWIN'72 is offline   Reply With Quote
Old 01-12-2014, 05:55 PM   #2
67ctener
67ctener's Avatar
Re: To shave or Not to shave that's the question
Since you asked... Don't shave
67ctener is offline   Reply With Quote
Old 01-12-2014, 05:57 PM   #3
CG
BlahBlahBlah
Its been done lots of times. I don't have any threads saved because its not my thing. Im sure there will be some fellas that can point you in the right direction.
Old 01-12-2014, 06:01 PM   #4
JIMINITWIN'72
Any particular reason, or is it a preference thing. No offense intended just curious.
Old 01-12-2014, 06:06 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Just depends on what your plans are for the truck.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-12-2014, 06:39 PM   #6
zeldman
zeldman's Avatar
The first shaved one I saw, I didnt even notice it until the owner pointed it out. I thought it looked just fine.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-12-2014, 06:48 PM   #7
jocko
jocko's Avatar
It drastically reduces the rigidity when the seam is opened, but it is restored after it's re-welded. Have to be careful to not let things warp while it's open, that's all I believe.
Personally, I'm not a fan of doing it. However, if you're building a full-tilt show truck - that also has many other custom touches - then I can see doing this. In any other case, it'd probably look kinda out of place. If it was noticed at all. Then again, it's your truck, and if you are wanting to learn to do this mod and are willing to experiment with your own ride, then by all means, go for it. But just know the risks and enjoy. It's yours, in the end if you want a shaved rail and that's the only mod you do, that's completely up to you - enjoy and post pics!
Old 01-12-2014, 07:26 PM   #8
OKGMC4
OKGMC4's Avatar
Finished roughing mine in a few weeks ago. Still more body work to go. You should start at the back and only cut about 4 inches at a time and tack weld as you go to keep things square. I did both sides up to the front glass first, then did the front all at once. There is enough metal to lay it over, cut off the excess, and butt weld it. The front was by far the hardest part. If you google it there is an article classic trucks ran about it with pictures.
I don't see how it would ruin strength. May actually make it stronger. The factory only spot welded it and smeared in seam sealer. Once it's fully welded it should have at least the same support. Plus, a shaved cab won't let in water where the filler cracks and falls out and cause the roof to rust out.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-12-2014, 08:09 PM   #9
67ctener
67ctener's Avatar
Totally preference. When I first got my truck a little over a year ago, I was set on shaving my drip rail. The more I saw I changed my mind as I felt it just didn't look right. It's all in what people like.
Old 01-12-2014, 09:40 PM   #10
Jayschevy
Just make sure you have good door seals. I read somewhere that when the drip rail is gone there's a bigger chance for water getting in between the door and the cab.
Jayschevy is offline   Reply With Quote
Old 01-12-2014, 11:17 PM   #11
Rod Run
Rod Run's Avatar
EXACTLY!
With people saying it will look out of place, I would bet almost 90% of them would never even notice unless you pointed it out to them. To me, that is a perfectly subtle mod and definitely means it wouldn't look out of place
I did it on my 69 Camaro about 15 years ago and to this day hardly no one notices unless I point it out.
The one con to shaving the drip edge, is driving in the rain. Small price to pay for a real cool look though. If I had the chance to do it all over again, I wouldn't hesitate to do it exactly the same way
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-13-2014, 12:28 AM   #12
black_sheep454
IMO it looks a little funny because the windshield opening looks smaller because of the door openings.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-13-2014, 12:31 AM   #13
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Just depends on your style I'm more into the look of the drip rails but both look good.. Here's one I'm doing for a customer now..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 01-13-2014, 04:59 PM   #14
brad_man_72
the boat guy
brad_man_72's Avatar
Its been done many times. I've got a few more subtle mods to do before paint but here's mine as of a few weeks ago.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-26-2014, 03:44 PM   #15
JIMINITWIN'72
I would like to thank everyone for their input. And thanks for posting the picks. I will definitely take the advice and do about 4 inches at a time.
Old 04-29-2014, 11:00 PM   #16
Hwyjb
Yes. The question "should I shave 'blank' .... Is always yes. IMHO
Hwyjb is offline   Reply With Quote
Old 05-08-2014, 06:40 PM   #17
ivanuf2
ivanuf2's Avatar
For me the a big factor was also to avoid these rust areas in the future. My truck had really rusted drip rails once removed the water flows away.
ivanuf2 is offline   Reply With Quote
Old 05-09-2014, 07:30 PM   #18
virginiaslim
check this out, IMO the best way to go, or to make it easier just leave 1/4" of seam and form to keep an edge
http://www.streettrucksmag.com/c-10-...keover-part-2/
virginiaslim is offline   Reply With Quote
