Post Whore
![]() Join Date: Mar 2013
Anybody in the neck of the woods with 6 bangers??
I love the old school 6 cylinders...hotrodded or stock...I am currently working on hot rodding a 292 in my 66....Anybody here doing the same???
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Anybody in the neck of the woods with 6 bangers??
Not in your neck of the woods, but my next project will be a 292. My favorite is the 1970 C-10 and I have had one with every engine from a 283 to a 502. Now that I am older I am wanting to do an old school 6 cylinder. I have a 70 C-10 sitting next to my garage, 292 with a 350 trans and power steering. An old man truck for sure. The rust was free. I am planning a 3 duece 292 using Rochester 2 GC carbs, but not sure if I can find an intake. I might have to modify a two one barrel intake and just run two carbs.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
#3 | |
Post Whore
I think the Offy intakes that except the three carbs are for the 62 and older 6's. Dual carb is all they make for 230-292.
Here's my winter project for my 250.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Post Whore
Offendhouser makes intakes that will fit a 194-230-250-292 single, dual and triple. Clifford also, the 194(late version)-230-250-292 can use the same intake and exhaust.
sorry no pix but I have a 292 in my 54 belair and I love that valve cover on yours. I'm also running a 235 in my fleetline triple carb set up
I have a 292 in my ' 64 Lwb and 1 in my '82 Lwb . Had 1 in my '70 short step but that now has a 400 small block. Like the inlines better
I am a Referee of life.
Check out this thread for more eye candy than you thought existed.
http://67-72chevytrucks.com/vboard/s...d.php?t=258488
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I'm getting there, slow but sure.
292 in my Panel project: ![]() And the 250 in my driver: ![]() No V-thingys for me! ![]()
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
![]() Join Date: May 2012
I am running a 292 and a th350. just stock old school low and slow. would be nice to hop it up some day. love the gas mileage.
![]() Join Date: Feb 2002
Hi TJ: If by "Neck of the Woods" being a philosophical state of mind relative to L6s and especially, the 292... then I'm there. Obviously I'm not anywhere near Oregon.
I run a '68 292 L6 in my '68 C/10 Stepside. It's the original engine F0627XAE, on its 1st rebuild, bored .030 over, with Badger pistons, Crane 260H cam, Rhoads lifters, V8 307 intake valves [1.84], hi-volume oil pump, Clifford Research headers, Offenhauser intake, w/ Eddy 1404 500 CFM AFB-type 4 barrel carb and Pertronix Ignitor II ignition. It has turbo muffles on dual exhaust with a crossover tube. I run 235/85R16 tires on 16" rims, since the OEM 17.5" x 5.25" rims gave out with less than 300,000 on them. Rear is a GM 12 Bolt 3.73:1 Eaton Posi. I have 2 more 292 cores: One ran in the Stepside from 1977 to 2002 racking up 250,000 miles before I had to pull it when the mechanic said it had no action in #3 and #4 cylinders. Since it was bored thirty over in '77, the next rebuild will have to be .040 or .060 [301 CuIn!]. The other core is painted green and the casting numbers say it's a 1962-cast 292 for the '63 model year. I have a couple of projects on the siding. I need to rebuild my '67 K/10 Suburban, and I have a lot of parts that will comprise a '72 K/5 when assembled in the correct order. For the latter, I have a Rockwell T221/SM465 transmission/transfer case, and the very rare 292-specific, angled L6 crossmember. T
I was going to put in a rebuilt 292 6 cylinder, until I found a 6.2 diesel, but if the diesel dies, I still got the 292 their waiting its turn, they just look cool.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#13 |
![]() Join Date: Dec 2013
#14 |
Post Whore
Lump port head makes a major increase in power. If you do some research on the oem chevy 6 cylinder head you'll know why. lol. Airflow was last on chevys priority for the 6 cylinder head.
#15 |
I've got one that's still alive. What all do you have done on yours T.J.??
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
#16 | |
Post Whore
#17 |
Nice! I've always wanted to build mine up with a blower on it they look cool sitting on the side of the motor.
#18 |
I will be running a 250 in my grandfather's '70 C20. It's pulled out right now to be rebuilt. I plan on leaving it all stock if possible.
Here it is the way I found it. Here it is pulled out of the truck.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
#19 |
It looks tired. Poor motor. Did it even run before you yanked it out?
#20 |
Yes. It had been sitting for 20 years before I got it. I put new plugs, wires, cap/rotor, coil and a new fuel pump on. It took some fiddling with the distributor to get it running but it finally ran. Surprisingly, it ran pretty well, only a couple minor coughs and sputters. It's supposed to be the original engine and it was rebuilt once back around 1980. I'm going to be rebuilding it in college this spring.
#21 |
I'm here in Springfield running my 230.
#22 | |
Awsome..!!! Thanks for the info. Just waiting for spring and the new business to get off the ground then I will be putting a 6 banger together.
#23 | |
Post Whore
#24 |
Post Whore
Bump! Any updates?????
#25 |
Post Whore
C'mon! Here is a motivation picture.....
