ebay lsx swap adapters
I was looking online for some plates that are adjustable but not as expensive as the dirty dingo one and came across this on ebay...would this one work on my 74?
http://www.ebay.com/itm/301055754967 |
Re: ebay lsx swap adapters
That arch shaped cutout is a little pointless, but I don't see why not.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
meowMEOWmeowMEOW
The holes look to be in the right place. Just be wary of generic hardened hardware that comes with ebay stuff. I've heard everything from getting generic hardware store bolts, to black painted grade 5's (not in terms of the mounts, but various ebay parts over the years)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
DD adapters have been used by a lot of people with a great success rate. not to promote DD but in my opinion engine mounts take a beating and would not be where I would personally take the chance. I have DD mounts and have been abused as much as my little 4.8L will abuse them without fail. i guess a bigger deal if you have solid mount engine mounts vs rubber/poly. The mounts I bought was the entire upper engine mount as one piece, not an adapter to your old upper mount.
I am using those exact adapter plates on my 85 and they fit great! Hardware seems to be of good quality, 1 year and no problems thus far.
im thinkin now maybe I should just go with the dingos...may be well worth it in the longrun
I bought those exact plates as well. Pretty solid construction and the bolts don't seem like run of the mill hardware store stuff. Mine came unpainted but I imagine they'd look great powdercoated.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Picked them up last summer, so it hasn't been all that long. My truck isn't even tuned yet to be honest, but I've still driven it a few thousand miles on poly mounts. Seem to be doing fine. They have a really nice weight to them that gives me some confidence. I actually heard about them from ls1tech so you might want to search there too to find some reviews. Seller is cutthroat4x4 but I believe his real name is Matt.
ok kool man thanks...that's the seller...I have the mounts on my ebay watch list
So I ended up getting these mounts on ebay. I thought it came with the green thing in the pic above but the guy said it was just to show the adjustability feature and is not included. So how does the mount work since I have clam shell style mounts?
The green thing looks like a universal solid motor mount. You can use the clam shell bracket off of your block, different shape but same bolt pattern. Random pic from elsewhere on this site:
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#13 |
Go with the dirty dingo's simple and adjustable
#14 |
...and almost triple the price...
#15 |
#16 |
Do they clear low mount ac bracket ?
#17 |
I'm not sure...I'm not running a/c on mine
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
#18 |
Not sure if I asked you yet but are you using low mount ac bracket ?
#19 |
DD mounts allow you to use your column linkage, in the same location and the drive shaft does NOT have to be messed with fits in the same location and the valve covers do not hit the firewall, first time fit and worked great on my 78 SWB
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#20 |
Do you have to shorten your drive shaft with these mounts?
#21 |
I dont know yet as i havent started the actual swap yet but it is a 3 position mount plate...stock location, 1 inch forward and 1 inch back. Billett and Blackpony are running these mounts too...maybe they'll input some info about the driveshaft
As for the shift linkage I have a b&m floor shifter in my truck so ill have no problems with that...hopefully lol
#22 |
I painted them and mounted them to my engine yesterday...fits up perfect and the hardware works well
#23 | |
![]() Join Date: Sep 2005
not really true i used the drity dingo sliders and only thing that lined up was the stock linkage, i had to shorten my drive shaft over 6 inches
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
#24 |
I swapped to a 4l80 so I needed the driveshaft cut anyway. Same with the linkage, Mine was a 4 speed on the floor, with a 3ott column. Swapped to a tilt auto column and picked up the lokar shift linkage kit. No problems with clearance issues though.
#25 |
I have a feeling ill have to cut mine too...im going to be runnin a 4l60e
| Bookmarks |
