Old 01-13-2014, 11:32 AM   #1
Custom 68
Custom 68's Avatar
Hydroboost: what size aftermarket master cylinder?
I didn't want to step on Mooseknuckles thread since mine is a bit different.
What bore master cylinder would you suggest if swapping to hydroboost? I have the "boost" setup and am tired of my current master cylinders leaking so I was going to step up.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 01-13-2014, 04:14 PM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: Hydroboost: what size aftermarket master cylinder?
Assuming its 4 wheel disc 1 inch Wilwood is what we use.
CHRIS67GMC is offline   Reply With Quote
Old 01-14-2014, 07:19 AM   #3
D13
D13's Avatar
Does this bolt on directly? In other words, if I have hydroboost, all I would have to do is just swap out the master?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-14-2014, 09:18 AM   #4
CHRIS67GMC
CHRIS67GMC's Avatar
Yes it will bolt right on. They come in 3 finish options natural,Media Burnished (light polished) and black. You can also get it with prop valve installed.
Pm me on pricing.
Old 01-14-2014, 01:29 PM   #5
Custom 68
Custom 68's Avatar
I will drop you a PM for some pricing but mine is front disk and rear drum, nothing fancy. I do have the wilwood D52 replacement up front.
I had collected the makings for a swap but didn't have the master cylinder plus my "factory" one looks like crap and I seem to have a bit of seepage I can't fix.
Dave
Old 01-14-2014, 06:07 PM   #6
CHRIS67GMC
CHRIS67GMC's Avatar
The master will be fine on disc drum as long as it has a prop valve 10lb residual vavlve.
Old 01-30-2014, 05:29 PM   #7
vannatta20
vannatta20's Avatar
I got this on mine for cheap. 40$ i think. Mine came with a nice looking reservoir ,
http://www.autozone.com/autozone/par...dentifier=2097
I had to elongate the holes for it to bolt up. Uses standard 3/16 line inverted flare fittings
vannatta20 is offline   Reply With Quote
