01-13-2014, 12:21 PM | #1 |
Cargo Lamp Conversion
I've been searching for information on converting my cargo light to a third brake light. I found that a lot of members here have done various types of conversions and I was wondering if I could just replace the existing lamp with a bright red led. Of course I'd have to run a wire or two but it seems like this might be the simplest way to do it. I noticed that the existing lamp has two posts and a single filament. Does anyone know what LED lamp is used to replace with?
01-13-2014, 01:03 PM | #2 |
Re: Cargo Lamp Conversion
Subscribing, but would be curious of you could have both a 3rd brake light with a built in cargo light
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-13-2014, 02:11 PM | #3 |
The Older Generation
Did you see the how to in the FAQ Forum by Longhorn Man? LockDoc
01-13-2014, 02:20 PM | #4 |
01-13-2014, 10:42 PM | #5 |
I am looking at doing the same thing. I picked up a small LED light from Advanced Auto and have done a mock set up. I think I can get it to work without having to remove the cargo light bulb. I'm waiting for it to warm up so the adhesive will stick.
01-14-2014, 12:34 AM | #6 |
Moderator
I'm not sure if you are just wanting an LED, or if you want something different. Check out this thread It is the one to which LockDoc was referring.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
