01-13-2014, 03:33 PM | #1 |
What's a good price, complete rear end, posi
I'm looking for a posi rear end for my truck, with 3.73 gears. I've found a few and the prices sure range a lot. I'm just trying to get an idea what people have paid for them in the past, or what they feel they are worth. There's one local and the guy is asking $800 for it, seems a bit high to me, but really have no idea, It's factory, never been rebuilt, so I'm guessing I'd have to freshen the unit up and replace bearings and seals at an added cost.
Any ideas? Thanks
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
01-13-2014, 03:58 PM | #2 |
Re: What's a good price, complete rear end, posi
Really, that's not a bad price, considering it would take about $1000 to rebuild one.
A surplus outfit www.Colemans.com has 10 bolt GM axles, new on a pallet, for $600 thereabouts, but they are 3.08 with GovLoc limited slip. I have heard people say the Gov-Loc is a bomb and can frag on you. These axles are for the Squarebody trucks anyway.
01-13-2014, 04:04 PM | #3 |
70+ ( Old Skool Club )
In Sept 2012 I bought a redone 12 bolt posi with 3:08's and new wheel cylinders, brake shoes and good smooth original drums and painted with a chrome cover. The seller was wanting 650.00 and I ended up with it for 400.00.
I say the seller is asking way to much at 800.00 for an original. If you can be patient and keep looking I'm sure you will find a beter deal. Put a wanted to buy ad on the parts board.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-13-2014, 04:07 PM | #4 |
Post Whore
I could buy a whole truck for that much.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-13-2014, 04:11 PM | #5 |
18 Till I Die
I would buy one from a wrecker and your gonna rebuild it anyway so put the money into new parts(auburn posi, gears, etc) Rather than trying to find one already done.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
01-13-2014, 04:11 PM | #6 |
Moderator
x2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-13-2014, 04:27 PM | #7 |
Roadtrip!
I assume it is for a 1/2 ton? If so, the 5 lug coil springs bring about $400 around here. The 6 lugs with leafs bring around $300.
$800 is way high...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-13-2014, 04:50 PM | #8 |
I bought a 3.73 ring gear and eaton posi for 450 on ebay with shipping. payed a garage 200 and change to rebuild my old rear end. Total was about $700. so 800 is a bit high unless it has been rebuilt.
01-13-2014, 06:29 PM | #9 |
Thanks for the reply's so far. I figured it was high, at the same time, I hardly ever see them come up for sale around here. Just with phone conversation, I got him down to 500, I'm sure if I show up with green, I can do better. I'd buy it for 400 if he came down that low.
Next question, his is a 6 lug, the rear end is a '69, and mine is a 5 lug, I'm assuming the axles are the same and I can put my 5 lug axles in?
01-13-2014, 06:39 PM | #10 |
I have put 6 lug axles in place of 5 lug axles, just have to pull and count splines. I understand not all years interchange. Last 6 lug 3:73 posi I bought was 10 years ago and I paid $300.00 and still replaced all bearings and seals.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
01-13-2014, 06:40 PM | #11 |
Moderator
Nope, different lengths. 71-up is a wider housing.
01-13-2014, 06:42 PM | #12 |
69 rear end may be a narrow rear end compared to your 71 5 lug so the axles may not be a direct swap. I ended up buying everything new for my rear end, I'll have around $800 into it after I pay a guy to help me put it back together. Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
01-13-2014, 07:09 PM | #13 |
Thanks for the info. At this point, is it worth trying to beat the guy up more and just try to buy the center section and pinion gear? If i have to buy new bearings anyways to rebuild it, I'd have to re-set the pinion again I'm guessing?
01-13-2014, 07:13 PM | #14 |
Moderator
You might want to look at it anyways, just to confirm it IS from a 69 for sure. About mid 70, GM went to the wider rear end, and your 5 lug axles would fit. You can also buy 5 lug axles aftermarket that will fit the narrower housing. I believe they are reasonably priced on eBay.
I would swap out axles as it is easy. Swapping the center out you will have to mess with the ring and pinion and I would avoid that.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 01-13-2014 at 07:20 PM. |
01-13-2014, 07:25 PM | #15 |
Thanks again for the reply.
Is there a casting number the guy can give me to confirm the year? While it is local, it's still a 250 mile round trip drive for me to check.
01-13-2014, 07:48 PM | #16 |
Moderator
This might help: http://67-72chevytrucks.com/vboard/s...d.php?t=527423
01-14-2014, 12:05 AM | #17 | |
3.73:1 ring and pinion--$191.00 Eaton posi-traction carrier--$419.69 Full install kit--102.48 so, if you set up the new innards you keep your housing and get a new Diff for $713.00. Plus you avoid all of the problems that put a used rear end up for sale in the first place. What could be better? |
01-14-2014, 12:41 AM | #18 |
You don't want the narrower rear end. They're 1.5" narrower, which doesn't sound like much until you want your back tires to fit the wheel wells and not looked sucked in. You can run spacers if you would like. I'd do what is suggested above, even at 4-500 for that axle, the posi is likely worn and would need to be rebuilt anyway, so just build yours like you want it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-14-2014, 02:37 AM | #19 |
Captain Obvious here. Ask the seller to throw a tape measure on it an give you the measurement. If its a 6 lug it will be narrower than a 5 lug. As mentioned above i wouldnt bother with the conversion axles as the rear will give you headaches when selecting wheels
Imo, shop around for the gear ratio you want and a posi and find someone to set it up for you. You will be happier than using an unknown used rear that may have bad axles, bearings, slipping posi that whines going down the road. |
01-14-2014, 12:29 PM | #20 |
Settin up a rear end even with all new parts looks and sounds real easy, when you see someone do it with the right tools and experience.
I recal way back 66'ish I did one in my friends 64 Impala hardtop ( and I have only done a few since I have avoided the hassle and smell ). Our first trip back down Speedway Blvd in Tucson AZ, every dog in town was howling. Question was were we going to make it back to base before it seized. LOL Boy did I ever get some first hand butt kickin quick. Dan |
01-14-2014, 12:38 PM | #21 |
Xx
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-14-2014 at 12:43 PM. Reason: delete |
01-14-2014, 12:39 PM | #22 |
never "assume" anything with swapping parts in rearends, and other stuff. what trans are you running that needs 3:73? what engine running that needs positraction?
01-18-2014, 08:54 PM | #23 | |
01-18-2014, 10:27 PM | #24 |
Thanks for the smart azz remark Fitz. I admit caught me off guard.
Didn't have a manual, he didn't have any money and we found what we thought were the right parts in a junk yard. Not to be concerned Fitz, I've done okay since. Dan |
01-19-2014, 09:54 AM | #25 | |
There is a whole lot more to it than most people think...reading the manual sounds easy, but most guys run out of patience before it is perfect. Pressing the bearings off-on, more than once gets old, especially if something slips and you ruin one.
I have rebuilt quite a few that the owner "tried" to do himself, all because they got it "close" ....and close is not good enough. If you run it "close", it is destroyed, and you start over from square one. Pay a professional, get a warranty......priceless
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
