Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-13-2014, 03:52 PM   #1
BowlerJon
Bowler Performance Touch-N-Go Start System
THE INDUSTRY’S FIRST TOUCH SENSITIVE START BUTTON WITH INTERACTIVE LED DISPLAY. MADE AS A DIRECT REPLACEMENT FOR STANDARD KEYED IGNITIONS!
here is a short clip we did explaining our Touch N Go system
https://www.youtube.com/watch?v=KA2oJ1rSRl8
67-72 Forum Price $549.95
SIMULATES FIVE POSITIONS OF KEYED IGNITION: OFF, ACCESSORY, ON, CRANK, AND RUN.
FIRST TOUCH: Simulates Accessory position turning on only consumers such as your radio to conserve energy and save sensitive components such as heated 02 sensors and engine computers. (which may suffer from being turned on unnecessarily)
SECOND TOUCH: Simulates On position which is typically connected to power windows, engine computer, gauges etc.
THIRD TOUCH: Simulates Off position.
A push on the brake and momentary press on the switch engages the starter. Starter is automatically disengaged once “Touch-N-Go” senses the engine running. A convenience found in many modern luxury vehicles.
Another push at any time returns the ignition to an off state. It’s just that easy!
Interactive built in led display allows for visual conformation of simulated key position. A theft deterrent pulsing red light when vehicle is off is included.
Will accept input from any momentary switch, including popular O.E.M. ignition switches!
Tach-less input allows for easy installation with any type engine. Built-in circuitry monitors state of engine to determine when it is running.
Optional security enable input allows for interface with security devices allowing only authorized users access to your vehicle’s ignition.
Available retained accessory option keeps accessories live for ten minutes after ignition is turned off, or until door is opened.
**May add additonal installtion time on 1980 and Newer Vehicles**
Please consider if this product is right for you. Newer vehicles and vehicles with locking columns and or security may make installation more difficult than intended.
BowlerJon is offline
Closed Thread
