Old 01-13-2014, 07:39 PM   #1
c10 custom
mystery misfire
hi everybody i am working on a 1989 gmc truck 4x4 350 5 speed manual trans
i have a misfire at idle and when accelerating it is misfiring slow and high speeds. New spark plugs wires cap and rotor ignition module map sensor
throttle position sensor the fuel pressure is 13 psi whitch is correct
tested coolant temperature sensor and temperature resistance readings are correct i am wondering how to test the ecm and the electronic spark control module on the side of the throttle body to me it feels like a spark related misfire any help would be greatly appreciated thank you
c10 custom is offline   Reply With Quote
Old 01-13-2014, 09:57 PM   #2
speedygonzales
speedygonzales's Avatar
Re: mystery misfire
Do a compression test
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-14-2014, 10:05 AM   #3
stevejohnson48
Re: mystery misfire
I once had a non computer vehicle that had a miss like your describing??/ I Thought it was the intake valves ??/ (Burnt valve ) I took them in for a valve grinding job and the tech machinist told me it was a flat lob on my cam ??/ Sure enough loaded the heads back in the car the next day or so replaced the cam and timing chain and problem solved ??/
stevejohnson48 is offline   Reply With Quote
Old 01-14-2014, 11:40 AM   #4
mountie
mountie's Avatar
Re: mystery misfire
Whenever I hear "new spark plugs / wires", I remember a past issue.
( was the miss-fire BEFORE replacing them?? )
New plugs can have defective-hair-line cracks on the ceramic.
I had new MSD wires with poor assembly in the factory pre-installed boots.
I also experienced this at a high-end race shop, when a customer had a miss, and the wires & plugs were newly installed and didn't consider this.
( A couple years ago, I had a new MSD cap fail at the center coil button within 30 days)
mountie is offline   Reply With Quote
Old 01-14-2014, 06:52 PM   #5
c10 custom
Re: mystery misfire
Thanks everybody for the replys it was a bad plug wire
Old 01-15-2014, 03:00 PM   #6
mountie
mountie's Avatar
Re: mystery misfire
Good to hear! ( Not a bad thing to replace other stuff anyway ) ( MSD wires & products are not what they used to be)
And, Spark Plugs..... There are the 'A' stock & 'B' stock....
'B' stock of plugs are made in places like China, made in huge lots, sold to places like large auto parts stores.... pallets of them at a time.
You will find tiny ceramic cracks, etc, not caught at inspection.
'A' stock of plugs are made in the 'original type factories, sold in smaller amounts, mostly to speed shops, etc. These have a better QA control.
