Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-13-2014, 07:47 PM   #1
texjake
texjake's Avatar
Dash speaker size??
What size speakers or speaker can replace or fit in the dash on a 68' with the original radio & A/C? I was able to find one post where some guys have custom fitted two 4" shallow speakers in the dash. I was wanting to know if a 5x7 or two 6 1/2" speakers can fit in there? The ones I have are not shallow, just regular aftermarket speakers. Isn't the original size speaker a 4x10?
texjake is offline   Reply With Quote
Old 01-13-2014, 08:02 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Dash speaker size??
Be sure you use the correct ohm rating with a factory radio. Believe it's 8-10 ohm. I bought a new upgraded speaker from these guys http://www.turnswitch.com/speakers.htm
You want the 4" X 10" Delco special rectangle. Sound is better than the original and won't mess up your radio.
FirstOwner69 is offline   Reply With Quote
Old 01-13-2014, 08:35 PM   #3
texjake
texjake's Avatar
Ok thanks. I am planning on replacing the AM radio but I'm sure the new deck will be about the same size as the original radio, so at this time the speaker ohm's & the radio ohm's are not an issue, I'll make sure that all matches. I'm just concerned about the size & space under the dash for some better sounding speakers.
Old 01-16-2014, 02:50 AM   #4
swamp rat
swamp rat's Avatar
Do a Google search on dual voice coil speakers, sterio sound one speaker.
Lots of threads here too.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
