radiator
Has anyone used this and any pros or cons on it?
thanks http://www.summitracing.com/parts/gr...del/c10-pickup |
Re: radiator
hmmm I'm interested. I was just planning on using my original 4 core, but at that price I might be willing to upgrade.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
![]() Join Date: Sep 2005
Re: radiator
Yes just installed mine its a great price but no were to mount fans.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Old member
That is a great price. I live about 30 minutes from them. I may have to take a ride. My electric fans use the zip ties through the radiator for now. I will make my own brackets for them later.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: radiator
Thanks guys, il be ordering mine tonight.
Re: radiator
I picked up a champion from Pro Performance here on the boards. $200 for a three row aluminum. Works awesome so far.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Vintage Evil
Re: radiator
Here is the Griffin one with fans attached...
http://www.summitracing.com/parts/gr...3-ls/overview/ |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: radiator
I have an American Eagle ( sister to Champion), dual core with 1" tubes, supposed to cool to 600HP. I also got two 11" puller fans at the time I purchased. I had a Champion and it started to leak around a weld ( after 4 years of use), I sent it back and they sent me this AE for free. Champion/American Eagle have lifetime warranty. I got it from Reliable Radiator.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#9 | |
Re: radiator
Old member
I wonder if a radiator shop could swap the fittings around so that they would work with a LS swap. I have a extra 4 core I got a long time ago that I have been sitting on just in case I needed a extra one.
Re: radiator
If you decide on the spare 4 core, you can look at jagsthatrun.com and get anadapter to go from one size to the other ( This is what I did) and also they have them for the steam ports too.
Good luck!
#12 | |
Old member
![]() Quote:
