original jack?
do you fellers think this is the original jack for my '72
i was surprised to find it hidden deep down in the rear passenger side corner
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
Re: original jack?
Yup that's it, should be a sticker somewhere around there with jack details. At least that's what's in my 72'. Pass side next to gas tank.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
Re: original jack?
thanks man!
#4 | |
Moderator
![]() Join Date: Jun 2008
Re: original jack?
![]() I second that.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Re: original jack?
It probably is. I have the original jack in mine too. I think it's held in there by a coil spring. My dad might have "used it once to help this guy" or something.
I don't go anywhere without a jack (or two, as in my Honda) so I'll probably add a floor jack to the bed once I get the cover put back on. |
#6 | |
![]() Join Date: Aug 2008
Re: original jack?
Imo a hydraulic bottle jack is a better addition. I worked with a guy who used to lug a big three ton floor jack around in his conversion van. I went to lunch with hom once and it was banging around in back. Maybe im missing something but i carry a bittle jack, coveralls and a piece of cardboard. |
Moderator
![]() Join Date: May 2007
Re: original jack?
Yup that's the original. As stated above a bottle jack is a good idea to have on board.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#8 | |
Re: original jack?
I tie everything down so it won't be rolling around but I may adopt your idea, just for compactness! |
Re: original jack?
I asked my coworker how bad his hernia was loading and unloading that thing! Years ago my dad (a welder for 30 years) built be a shoe that goes on the end of the bottle jack. It is 1" od to fit the jack and a 6" long piece of 2" pipe sliced in half and weld to the 1" at 90 degrees. It you had to jack up a trailer on the round axle, we would use the shoe to keep the jack from slipping off.
Re: original jack?
thanks everyone!!! this forum rules!!!
Re: original jack?
I agree with others here, it is the original. That jack will offer you many opportunities to learn new swear words if you try to use it. But it is better than nothing in a pinch. As others suggested, I carry a bottle jack and and short peices of wood to put under it and to use as a chock if needed.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
Re: original jack?
Dean do you have the little clip with the spring behind the pass side seat?
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
#13 |
Re: original jack?
FWIW, the first time I needed to use the original jack, I learned that it did not jack the truck up high enough. Luckily I right next to a landscaping crew that had a jack which worked.
Hook'em |
#14 | |
Re: original jack?
#15 |
Re: original jack?
i tryed this jack once and it just bearly lifted it high enough. i think ill carry a block of wood along
#16 |
Re: original jack?
yes i do. how does that work?
#17 |
Re: original jack?
is this it? i knew it had something to do with the jack
#18 |
Re: original jack?
that spring holds the bars in place there should of been a bag for the bars......there should be a tab on the floor pass side with a spring on it that holds the jack in place
#19 |
Re: original jack?
#20 | |
Re: original jack?
#21 |
Re: original jack?
yup. The handle came with a foam bag and sat in the corner secured by a spring clip. And for sure keep a piece of 6"x6" timber if its your only jack.
Figure out what you want--then figure out what you are willing to give up to get it. |
#22 |
Re: original jack?
thanks for the reply and pics! helps alot!
#23 |
Re: original jack?
good one Lou my truck is tore down had to dig thru a box to find the spring to get a pic.
