![]() Join Date: Dec 2006
Side Window Glass Won't stay in bottom channel
I tried searching here. I looked in two manuals and didn't see any instructions on how to keep replacement glass from coming out of the bottom support channel (or whatever you call it). When I put it in I didn't have anything better so I used ABS glue that I happened to have in the truck. Came right out and dropped to the bottom as I was walking away!
What is the proper and permanent way to secure side window glass to the metal channel it sits on? Thanks a lot. Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Moderator
![]() Join Date: May 2007
Re: Side Window Glass Won't stay in bottom channel
Glass setting tape. There are several thicknesses available from the truck shop in orange. I had no luck finding it from any other vendor. You can also purchase it at a glass shop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
you must clean it good and use urethane or silicone let dry and then reinstall
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Maybe take it to a windshield shop and have them glue it in with some urethane adhesive? They may only charge you a couple of bucks if they have a bit left over after a windshield install.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Thanks guys. I will try the tape first. -Brian
![]() Join Date: Jan 2001
Glass tape is the OE solution. Urethane glass adhesive will work too, as will a special glass-setting epoxy. I wouldn't recommend using silicone under any circumstances. It will eventually work free, and it's really hard to get something to stick to glass once silicone has been on it.
Moderator
The tape is the proper way to do it, I am sure there are other ways, but this worked for me. Cut the proper length, fold it in the middle, tuck it in the channel. Line up (center) the channel on your glass, and GENTLY tap it on the glass with a small ball peen hammer or mallet. It will NOT come out once set so make sure it is centered properly. I did one side at a time, so as to compare and make sure I kept it centered properly. Good luck!
OK, I'll get some tape. First I guess I have to get all that ABS glue out of the channel. Lacquer Thinner maybe? thx Brian
I have used both the glass tape and weatherstripping adhesive. Carefully use a mallet or a small tack hammer and a few bumps on the bottom to seat it flush with the glass. You can get the metal support strip to far in one direction causing the regulator too bind somewhat.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#10 | |
Florida Edition
![]() ![]() Join Date: Oct 2010
--Posted for informational purposes only ; Dow Corning(R) 995 Silicone Sealant Excels in Structural Bonding and Protective Glazing Applications MIDLAND, Mich. – April 21, 2008 – Dow Corning® 995 Structural Silicone Sealant is a one-part, neutral-cure adhesive that cures to durable elastomeric rubber. It combines high tensile adhesion strength (150 psi) with superior tear strength (49 psi) and offers excellent, unprimed adhesion to most common building substrates, such as glass, reflective glass, anodized aluminum, granite and paints, including most fluoropolymer-based paints. “Dow Corning 995 sealant is particularly well-formulated for structural glazing applications and new impact-resistant protective glazing systems,” said Mike Blaszkowski, Dow Corning Construction Market Manager. For example, it is used to protect the 2,559 windows of the CNA Financial Plaza Building in Chicago from the harsh impacts created from sudden atmospheric windloads. Dow Corning 995 sealant is the only approved sealant for the 3M Ultraflex System, it satisfies the demanding impact/hurricane structural glazing standards required for new construction in Dade County, Florida, and it meets bomb blast requirements for new structural glazing systems.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Dec 2013
I've installed thousands of windows and anything less than urethane is a waste of time and money , buy a tube from any glass shop and be done with it .
#12 | |
I'm just talking from experience. Every time I would get a call on a leaking windshield, if I pulled up and saw silicone, I knew it was going to be a fight to get the glass to seal. Besides, there are much better options. Why not just use one of them? |
#13 |
Any type of silicone is prone to fretting in a vibration area . urethane stays where you put it .
