Bowler Performance Transmission Guardian
67-72 Forum Price $55.00 Winner of The Good Guys 2012 Product of The Year And The Hot Rod Restoration Design Award Transmission Guardian is a small color changing LED that you can mount on your dash to give you a visual indication of your transmission temperature. The LED turns on at 135° and changes colors as your transmission temperature rises. Please refer to the chart as to what each color indicator means. Transmission Guardian was designed with transmissions in mind but it can be used on engines, differentials or any source that can use our temp sensor. Transmission Guardian can be used as a direct replacement for temp gauges or can be used in conjunction with. 9 out of 10 Transmissions Fail Due To Heat |
Re: Bowler Performance Transmission Guardian
This is a cool little product for any one that uses there truck in any kind of performance driving event...
bump
![]() Join Date: Nov 2007
That's pretty neat, ill keep this in mind during my build when i get closer to this stage
