Heirloom '92 1500
This is my '92 Silverado. My dad bought this truck brand new, and I inherited it when I was 16. I'll never get rid of it, and it was time for the 235,000 mile 305 boat anchor to come out. I put together a 5.3 with a mild cam, longtube headers, LS6 valve springs and a camaro oil pan. Nothing crazy.
![]() ![]() ![]() ![]() ![]() ![]() ![]() I have all of the steering components along with the brake booster painted as well. ![]() This is where I'm at. Most will never notice, but I shaved the humps where the overflow/coolant reservoir used to be and the hole where the cruise control comes through the firewall. Getting ready to put it all back together now.
<> Severed Ties Texas <> Last edited by TexasEdition; 01-14-2014 at 04:12 PM. |
Re: Heirloom '92 1500
Nice work. That Ls will be a night and day difference from that worn out 305 slug.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Old member
Good job. I to went from a 305 TPI to a 6.0 LSx motor.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I love this guy! motor in the kitchen!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks fellas. I'm excited about it. I'm starting reassembly this weekend. I forgot to mention I'm keeping the 5 speed manual. I'm sure I'll have to upgrade to a t-56 later. I was tired of being cold and wet out in the carport (not good for parts anyway) so inside it came. lol
<> Severed Ties Texas <> |
I am so jealous !! Can't wait to start mine !! Looking Good !
I assume you have an nv3500. That should last a solid 10-15 minutes. Good luck. I would have the t56 waiting before the first test drive.
It's the Getrag, but yes, weak 5-speed. I don't drive like an idiot, and it's not a race truck. I'm not fortunate enough to have an endless supply of money or sponsors, so the t56 will have to wait.
That tranny is fine. I had it behind a 383 425 hp for many years and had no problems. Now i have it behind my 5.3 swap in my 1992 chevy pickup.If you do a ton of power shifting you will probably blow it up but i have done my fair share and it is still going strong.
Nice Job !! Looks Killer already !!! What a-arms are those--they look great all painted up !!!
#13 |
Thanks, bud. They are factory 88-98 1 ton arms. Have to slot and use the 1/2 ton ball joints in them.
#14 |
meowMEOWmeowMEOW
I must say man, You really worked hard to keep things "clean" since you started with such a clean base. Nice work, and I'm hard to impress.
What is that thing on the pass firewall with all the wires going into it, the square plastic thing? Is it a wire block, or is it just a squarebody thing I haven't seen before.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#15 |
Thanks, man. I appreciate it. Your truck is killer, by the way. My goal was to be simple, clean, and detailed. The "thing" on the passenger firewall is where all of the wiring goes to the original '92 computer behind the glove box. My 5.3 computer will be mounted near the radiator.
#16 | |
#17 |
Well, started it by jumping the starter.. (I forgot to plug the clutch start switch back in) and let it run for maybe 20 seconds since I didn't have coolant in it. Plugged the switch back in and now I have no spark. Any ideas?
#18 |
Nice build, sorry I can't help with your problem but I do have questions for you. What engine cover do you have on and what A/C set up do you have?
#19 |
Dbl post....
#20 |
![]() Join Date: Jun 2006
You probably shouldn't have wrapped your headers if you plan to DD this ride. In wet or high humidity conditions they will sweat and start to rust out faster.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#21 |
If it starts by jumping the starter, but won't start with the key, it sounds like you're loosing power in the crank position. You need power in both crank and run positions. What wire do you have powering up your 5.3 harness? Should be the wire that originally went to your 305 distributer.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#22 | |
#23 |
It's not a daily driver. If it gets driven in the rain, it will be an accident.
#24 | |
#25 |
[QUOTE=TexasEdition;6523746 Everything, including the PCM had "key on" power when I turned the key into the "on" position. [/QUOTE]
But does it have power in the "crank" position? Some ignition sources will have power in the "on" position, but will loose power in "crank". If you have it hooked up to one of those, then it wouldn't loose power jumping the starter, that's why I thought you may be loosing power.
