Old 07-19-2003, 10:21 AM   #1
suede71
wheel hop in reverse
Hi.
I am getting excessive wheel hop while backing up in reverse. Could this be a pinion angle problem? I have the two piece drive shaft and my truck is lowered 7 in rear and only 4 in front. If front is slightly higher than rear could this cause pinion probs. The rear is lowered by 5 inch coils and 2 inch blocks. Shocks are at correct angle.
Any ideas???
Thanks,
Tristen
suede71 is offline   Reply With Quote
Old 07-19-2003, 10:54 AM   #2
Shane
Shane's Avatar
Its because when you are going in reverse, the motion of the rear wheels try to "unwind" the springs. Tthe springs are wound so that their force is being used when going forward (the motion of the truck moving forward compresses the springs) and when you go in reverse, the motion of the truck tries to "unwind" the springs. Once the weight of the truck is lightened or taken off the springs, they tend to bounce.
Shane is offline   Reply With Quote
Old 07-19-2003, 12:31 PM   #3
sgtjed
What if?
sgtjed's Avatar
um why in reverse?
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 07-19-2003, 10:44 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
My exact question!! WHY REVERSE
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 07-19-2003, 11:19 PM   #5
krue
Designated A-hole!
krue's Avatar
My understanding is that when you are going forward the torque on the trailing arms (which are connected roughly in the middle of the truck) pull the weight of the truck onto the tires giving you traction, but in reverse it will push the weight of the truck up, therefore wheel hop.
I could be wrong tho!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-20-2003, 03:37 AM   #6
houston6
houston6's Avatar
I had the same problem once.i went with a one peice driveshaft and it solved my problem.
Scott
houston6 is offline   Reply With Quote
Old 07-20-2003, 12:01 PM   #7
Shane
Shane's Avatar
weight transfer ... thats why it does it in reverse and not forward. When moving forward, the weight attempts to transfer to the rear of the truck ... thus pushing down on the rear and compressing the springs. When going in reverse, the weight tries to transfer to the front of the vehicle which "uncompresses" the springs ...
