Rollin' Old Skool
Fan clutch wobble/play?
Is there any amount of play/wobble that's acceptable with the fan clutch? While taking everything apart over the last couple days to inspect for my chirping noise, I discovered that I can slightly wiggle the fan if holding the blade edges. I had read somewhere where slight play is allowed, but I've ready many other things that say there should be no play/wobble at all. Just to note, I haven't had any noticeable cooling issues or anything since I've owned it (1 year).
This is on my '97 Tahoe with 5.7L Vortec if it makes any difference. Thanks for any info!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
The One And Only !!!
Re: Fan clutch wobble/play?
Technically......There should be no wobble.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Rollin' Old Skool
Yeah, no wobble on mine. It's barely a wiggle. I'd say less than 1/16". I don't think it's an issue but just wanted to make sure.
| Bookmarks |
