Old 01-15-2014, 07:25 PM   #1
Steve Cole
Power steering pump differences
Does anyone know what the differences are between the late sixties and the late eighties pumps ? Not the cosmetics, I know the later pumps had metric threads and used O rings for sealing, but do the later pumps work any better? Are they smoother? Any advantage to running a later pump? I'm talking about pumps with reservoir attached. Thanks!!
Steve Cole is offline   Reply With Quote
Old 01-15-2014, 08:50 PM   #2
Tinkermc
Re: Power steering pump differences
in 73 I think it was the ps pumps went to 3.5 turns lock to lock and b-4 that it was 4.5 so newer pumps seem like sports car handling.
Tinkermc is offline   Reply With Quote
Old 01-15-2014, 10:08 PM   #3
Fitz
That's the steering gear, not the pump.
Fitz is offline   Reply With Quote
Old 01-16-2014, 09:03 AM   #4
Steve Cole
So then, are the pumps basically the same?
Old 01-16-2014, 09:44 AM   #5
Fitz
Yes. Mounting brackets and internal seals changed but pressures and flow volume are about the same.
Old 01-16-2014, 10:21 AM   #6
chewychevy67
not sure exactly when the change was but the later pumps have a press on pulley shaft and the 60's era were mounted with a keyway and a nut.
chewychevy67 is offline   Reply With Quote
Old 01-16-2014, 10:31 AM   #7
Sammy
Pulley n bracket mounting could be a nightmare unless you switch to a complete setup. I have never tried it. But have in a complete serpentine. Noticed no difference in performance of the pump itself.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-16-2014, 10:49 AM   #8
hugger6933
Except the press on and nut on shaft type[don't know what to call it but that don't sound right]there is very little diff. The shaft that has the nut is a tiny bit smaller so that a press on type pulley can't be used on that kind of pump. Jim
hugger6933 is offline   Reply With Quote
Old 01-16-2014, 10:50 AM   #9
hugger6933
their whole thing is just to push fluid with pressure and do it for a long time
Old 01-16-2014, 11:16 AM   #10
ray_mcavoy
I believe 1974 was the last year for the keyed shaft/pulley with a retainer nut.
ray_mcavoy is offline   Reply With Quote
