Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-15-2014, 08:18 PM   #1
Scottcoda
Scottcoda's Avatar
Powder coating rims..pricing
I am currently looking into getting my steel rims powder coated, I tried find new ones online but not very much luck, I priced a local vender for powder coating my originals. The price includes striping the old rims, powder coating the faces (outside only) of the rims in black then adding a clear coat for $80.00 a rim. Should I continue searching for new black 16 inch 8 lug rims or buck up the $320.00 for the powder coating? I thought of doing a spray can job but not sure how they would look...Thanks for any input
68 GMC 2500 stepside LWB 250CI
Scottcoda is offline   Reply With Quote
Old 01-15-2014, 09:20 PM   #2
slikside
slikside's Avatar
Re: Powder coating rims..pricing
That seems high to me.
A couple years ago I paid $50 per rim AND dogdish cap. That included sandblast and p/c front and backside. Did the spare too. No clear though.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 01-15-2014, 09:23 PM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I paid $50 a wheel complete blast and powder front and back a few years ago when I was stationed in SoCal. I was talked out of a gloss black into a satin/semigloss to reduce the cost as there is less prep required when it isn't going to be a high gloss surface. Also, I wouldn't think that a powder coat should need a clear coat, that may be adding to the cost.
If that's the lowest price you can get, I would try spray painting them first, worst thing that happens is waste of $20 worth of paint and taking them to the powdercoater.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-15-2014, 09:29 PM   #4
stomper
Junior Member
stomper's Avatar
A local chain tire store (Les Schwab) around here does black or white for $25 a wheel. Colors are $35. Blast and powdercoat. I realize were on the Left coast here but just to give you an idea.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 01-15-2014, 09:30 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
To others it may seem high, but $80 is about normal for a quality job in our part of the country. If you want something that's durable and trouble-free then powdercoating is the way to go.
I paid $85 a wheel here in Connecticut. They did a great job and they look as good now as they did 3 years ago.
EDIT: I just re-read your post and wondering why they would only do the outside face of the rim. If they're charging $80 and not doing the whole thing then, yes, I agree that that's high. Price around for a place that's lower and will do the whole job.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-15-2014, 10:54 PM   #6
mgchevyparts
mgchevyparts's Avatar
That is extremely high for my area. All powder coaters have a minimum charge for one color. Here it's about $70. I would guess I could get 4 wheels blasted and powder coated for the min at most $100 ALL FOUR.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 01-15-2014, 10:57 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Powdering the outside face only is hack. I'd run from that shop.
I charge 80 per wheel for single stage. That's the entire wheel not just the face. Powdercoat is just like paint work, you get what you pay for. If you shop for the lowest price you're likely to get the lowest quality.
Old 01-16-2014, 10:55 AM   #8
Scottcoda
Scottcoda's Avatar
Really glad I asked you guys for your input, I live in a rural area and the shop I priced is close to home. The closest other shop is 75 miles but after calling sounds worth the drive. They will clean up the old rims, put on a first stage of primer then do the black and of course that is for the whole rim for min charge of $50.00 and a Max of $75.00 depending on how much needs to be cleaned up. Sounds much better to me
Old 01-16-2014, 12:22 PM   #9
Grumpy old man
Grumpy old man's Avatar
For the low cost of the systems and anyone can buy a used kitchen oven for $50.00 why not do it yourself and save a few bucks ? do a few pieces for your buddies to pay for everything and get all your coating for free ?
Grumpy old man is offline   Reply With Quote
Old 01-16-2014, 12:58 PM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
I was quoted $450 to blast and powdercoat 4 15x8 ralleys.
Needless to say, I declined.
Same guy coated my 18s in clear for $50 each a few months ago.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-16-2014, 01:38 PM   #11
54blackhornet
54blackhornet's Avatar
$25.00 a wheel in NE Oregon !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-16-2014, 01:56 PM   #12
whitedog76
Check out Dexstar wheels. They're actually trailer wheels, but identical to the OEM steelies. For about $65, not too shabby. You can get them in Silver, black, or white.
http://www.etrailer.com/Tires-and-Wh...r/AM20766.html
http://www.dexstarwheel.com/products.pdf
Rickson Wheel has OEM Accuride wheels. You'll have to look under Ford F250 or E250 though. They're only $75 each, but they're brand new.
http://ricksontruckwheels.com/wheels-oe.php
whitedog76 is offline   Reply With Quote
Old 01-19-2014, 12:49 PM   #13
PatrickGMC70
PatrickGMC70's Avatar
Well I don't mind posting that either I got ripped off (big time) based on what you guys are posting, or prices in the Baltimore/D.C. area are crazy high compared to everywhere else.
I paid $125 per wheel. That included start-to-finish work, not coating an already-prepped wheel. They stripped the old paint, rust, etc. and matched the factory body color for me.
Before and after:
PatrickGMC70 is offline   Reply With Quote
Old 01-19-2014, 02:01 PM   #14
cdowns
cdowns's Avatar
a few hours of prep work a few cans of spray enamel and you can have real nicely coated weels for $20 for all four
Old 01-19-2014, 02:22 PM   #15
Tx Firefighter
Before and after:
Not at all. I'd have been at 120 per wheel for that job. You took him a set of cruddy wheels that required heavy blasting, then he put a two stage powdercoat job on them. That's a color base coat, then cured, then a clear topcoat and a second cure cycle. That's not quick, easy, or cheap to do a job like that.
Old 01-19-2014, 03:57 PM   #16
cableguy0
Before and after:
Who did you use. We always used east coast powder coating up in cecil county. They do really good work and stand behind it. I have literally had to beat on their work with a 5 lb hammer and didn't hurt a thing.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-19-2014, 09:33 PM   #17
PatrickGMC70
I used alloy wheel repair specialists. I think they're a franchise location. I called a few body shops about getting my wheels blasted and painted. The first two body shops I called said they farm out wheels, and they both referred me to these guys. They're off of Rt. 40 (Pulaski Hwy.) near Rosedale.
Old 01-23-2014, 11:34 PM   #18
pimpston65
pimpston65's Avatar
well i paid $125 for the complete wheel and spinner, they stripped it also. could have got it done for $70 if i drove 2hrs north, but 20mins is closer
pimpston65 is offline   Reply With Quote
Old 01-24-2014, 08:05 AM   #19
Tx Firefighter
Those wheels are exceptionally tough to coat. You paid a very fair price.
Old 01-24-2014, 08:26 PM   #20
pimpston65
pimpston65's Avatar
well good i didnt get rip'd off, plus its coated all over and shiny as all get out!!! im just afraid when the tires get put back on scratches and all, and i just bought a rubber mallet to hit the spinner on
Old 01-25-2014, 01:01 PM   #21
61K10
61K10's Avatar
the trailer wheels are a good price, but say the stud size is 1/2". can you sue them with 7/16" studs?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-01-2014, 11:42 AM   #22
LT1 Burb
LT1 Burb's Avatar
I got a set of wheels done at Les Schwab for 25.00 a piece but they powder coated over the rust and pitting. Great for a driver truck but not great for a show truck. You get what you pay for and I would rather pay the 50 a wheel that the true powder coater charges, I will never use them again.
LT1 Burb is offline   Reply With Quote
Old 02-01-2014, 12:19 PM   #23
Scottcoda
Scottcoda's Avatar
Update.. They company I was going to use dropped the ball and never returned my call to arrange a time for me to drop off the rims, So I called the company closer to my home to speak to him further about his process, After speaking with him he lowered his price to 75.00 a rim (was 80). he would do the WHOLE rim, Sand blasted, Powder coating then clear coat, I should get the rims back by 02/06/14, He also threw in a few small pieces I had for the tail/reverse light brackets for 20 bucks, I will post pics of the competed job when I get them back
Old 02-01-2014, 03:45 PM   #24
Rich916
Rich916's Avatar
Shop around a little. No rule that you need to use the same shop for media blast AND coating.
I found 1 shop cheaper for stripping the wheel and another shop gave me a better price for coating
2 different shops...Total $75.00 per wheel. That’s for a “stock” color. When you want custom colors the price will go up.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 02-20-2014, 11:27 AM   #25
Scottcoda
Scottcoda's Avatar
Got my rims back today.. $75 bucks for full rim and a clear coat that he said would make the rims "pop".. Happy with the work but not sure about the clear coat he put on .. Has a hell of a shine but maybe I should have gone with a more flat black or semi-gloss.
I also was going to go with chrome lug nuts but found these black one for about half price I think they will match up nicely. If they scratch or look weird when mounted I will just get the chrome ones, I also found aluminum black valve stems that keep the black thing going
