Old 01-15-2014, 08:52 PM   #1
sigshooter
sigshooter's Avatar
Big back window conversion tips
I started my big window conversion today and I came ascross a few short cuts. I drilled out the spot weld below the window/behind the tank, but instead of trying to drill out all of the welds around the lip of the window/underneath the seal. I used a grinder and cut off wheel and cut the outer metal of the donor cab. I cut it in a way that it was easy to fold it down at the window lip, opening up a "v" around these welds. I lightly hit them with the cut off wheel and just by working the two pieces open and closed/back and forth it popped the welds apart without drilling all of the welds. I continued to cut the outer part of the cab one section at a time and exposed the rest of the welds such as ascross the top headliner portion and continued the same process. It worked great and saved a lot of time drilling those hundreds of welds.
It ruined the rest of the outer metal, but all I wanted was the inner panel
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 01-15-2014, 08:53 PM   #2
sigshooter
sigshooter's Avatar
Re: Big back window conversion tips
Another
1966 Short stepside
1964 long bed
Old 01-15-2014, 08:56 PM   #3
sigshooter
sigshooter's Avatar
Another picture
1966 Short stepside
1964 long bed
Old 01-15-2014, 10:13 PM   #4
sigshooter
sigshooter's Avatar
Panel removed, now I just need to clean it up and remove a coupłe pieces of the donor cab that are still attached
1966 Short stepside
1964 long bed
Old 02-12-2017, 10:16 PM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
good stuff
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-13-2017, 12:33 AM   #6
shortstep60
How are you going to put your BBW section in your truck? I have done Three and I use 3m panel glue its fast you don't have to put a hundred spot welds. I have used it for ten years and love it I have a truck in my shop right now if you want me to send you some pictures.
shortstep60 is offline   Reply With Quote
Old 02-13-2017, 06:52 AM   #7
sigshooter
sigshooter's Avatar
I have a couple myself, I have a spot welder I use for most of it, simple and easy with no grinding to clean up. I use the 3m panel adhesive along the top where I can't use my spot welder.
1966 Short stepside
1964 long bed
