Old 01-15-2014, 09:50 PM   #1
layinframe
rear suspension
lookin to upgrade my rear suspension would like to get away from the leafs to some thing better would like to go a little lower and that can handle some hp some input would be appreciated
Friends don't let friends drive DONKS lay it out
My greatest fear is when I die my wife will sell all my truck parts for what I told her they costs
layinframe is offline   Reply With Quote
Old 01-15-2014, 11:14 PM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: rear suspension
No-Limit Fat Bar great forward bite.
CHRIS67GMC is offline   Reply With Quote
Old 01-16-2014, 11:26 AM   #3
Scottshotrods
Re: rear suspension
One more option will be our Scotts standard 4-bar kit.Let us know if you have any questions you can send us a e-mail at scotts@scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 01-16-2014, 11:46 AM   #4
Pro Performance
Pro Performance's Avatar
Re: rear suspension
What year truck do you have? Is this a 67-72 with leafs? or a later 73-87? Are you looking to switch to a coilover, or go with air ride? From your profile, it looks like this is for a 73-87.
A 4-link system will work well as mentioned above, but would also consider a trailing arm setup from Porterbuilt.
63-72 Version (Shown with coilover, but bags can be done.
73-87 Version (Shown with bags, but coilover can be done)
Pro Performance is offline   Reply With Quote
Old 01-16-2014, 11:51 AM   #5
markiemark
Re: rear suspension
subscribed... my 67 is sitting quite low now but on leafs. Is there a spring conversion yet keeping the cost low? Sorry if I hijacked your thread.. Thanks
markiemark is offline   Reply With Quote
Old 01-16-2014, 11:52 AM   #6
layinframe
Re: rear suspension
85 like to step notch it tryin to stay away from air
Old 01-16-2014, 12:45 PM   #7
CHRIS67GMC
CHRIS67GMC's Avatar
Re: rear suspension
First thing you need to consider is do you want any performance or adjustability.
Parallel 4-bars when at ride height you get what you have. Most of the time there mounted parallel so you get little performance gain. They are fine for a street car.
Trailing arms are a lot like a ladder bar. So if built at correct angles at ride height they can be effective. The negative here is pinion angle is fixed.
A true 4-link with adjustable brackets give you the best option to dial in your truck.
Here is a good article.
http://www.raceglides.com.au/files/f...erbar-tips.pdf
Old 01-16-2014, 01:33 PM   #8
Pro Performance
Re: rear suspension
You can search and acquire all the factory parts to convert over to a coil spring rear, or you can go with the PB stage 2 deluxe kit. The stage 2 deluxe kit can be ordered without bags, and would just place in your coil spring. I don't know of a kit other than this, that would be a "conversion" for you.
http://www.azproperformance.com/Port...eluxe-Kit.html
I understand. If wanting to do a static drop with a step notch in the rear, I would suggest a drop member up front to match that lower ride height and gain a lot of other benefits by switching.
Feel free to call me, and we can go over in detail. We can look at what ride height you want to achieve, plans for the truck, and what components would be good to achieve that goal.
Always best to research all options / manufacturers, and make your decision from there.
Travis
480-420-8175
Static dropped blazer on a PB front extreme coil-over setup. Custom rear setup.
Static drop on a PB front mild / rear stage 2 coil-over setup.
Old 01-16-2014, 07:28 PM   #9
layinframe
Re: rear suspension
np
Old 01-16-2014, 07:41 PM   #10
layinframe
Re: rear suspension
Travis
480-420-8175
would love for my ride height to be the same as the blazers on 24"s is that gunna happen . and more on the performance side
Old 01-16-2014, 07:49 PM   #11
Pro Performance
Re: rear suspension
You can have that low ride height with the extreme PB coil over version.... and still retain the performance aspect. Depending on how aggressive you want to drive, you may want to upgrade to the RideTech HQ coil overs vs. the RideTech RQ that come with the kit.
To maximize performance, I would suggest stepping down the diameter of the wheel, in order to shed some weight from the wheels. The larger wheels will have more rotating mass. But, understand some of it is for looks as well. Can't beat a slammed truck on big billet wheels.
Old 01-16-2014, 08:02 PM   #12
layinframe
Re: rear suspension
soon to be a weekend cruzer as far as aggressive would just be a light to light not to worried about handling don't plan on rallying it low fast and loud is what im goin for
Old 01-16-2014, 08:19 PM   #13
layinframe
Re: rear suspension
currant ride height but id like this just about 4"to 5" higher
