Old 07-19-2003, 12:28 PM   #1
Kman
HELP! rebuild timing problem
I have a 350 I just put together, all stock w/roller lifters electronic ignition. the thing will not stay running under 1500 rpm and about 15-20 degrees advance If I retard spark it pops out the carb. I rechecked valve adjustment and it was ok,rechecked plug wires ok I'm thinking the timing chain might have jumped a tooth
also the carb a rebuilt carter 4 barrel has fuel coming out of only one side,I took the top off and checked for something clogged but every thing is clear
My question is is the carb problem related to a timing problem or am I missing somthing else before I tear timing cover off to check it? sorry to be so long but this is driving me crazy
any help would be great, thanks
Kman
New 89 chevy 1500 driver
72K20 rust bucket project stripped down to the frame engine rebuild started
71 Blazer - another procect
Kman is offline   Reply With Quote
Old 07-19-2003, 01:01 PM   #2
Kman
anyone?
Old 07-19-2003, 01:11 PM   #3
jef5150
Inline 69
jef5150's Avatar
fuel on 1 side????with the engine "OFF" pump the carb a couple of times with your hand ,look into the carb while doing this.this is a way to check your accelerator pump in the carb,,,,you should see gas squirting on both sides,,,,,,,try that first,,,,,,,,id concentrate on the carb as being the problem....jeff
jef5150 is offline   Reply With Quote
Old 07-19-2003, 01:12 PM   #4
jef5150
Inline 69
jef5150's Avatar
if your timing chain jumped iwould think it would run rough at ANY rpm..
Old 07-19-2003, 01:22 PM   #5
Kman
accelerator pump is fine the left side of primaries has no fuel at low rpm at about 2500 there is some fuel maybe vac prob?
runs pretty smooth at 2000 but stalls below 1500 and pops through carb
Old 07-19-2003, 01:30 PM   #6
Kman
it sounds like firing order is wrong but I ran the wires twice they are right
Old 07-19-2003, 02:06 PM   #7
Kman
is there a way to tell if the timing chain is off with out pulling the cover??
Old 07-19-2003, 04:02 PM   #8
Kman
ttt
Old 07-19-2003, 04:26 PM   #9
GasHog396
Are you running a single or dual plane intake manifold? If it is dual plane, with no fuel coming through one of the primaries, 1/2 of the cylinders won't be getting gas. I believe the carb should be spitting out fuel in both primaries when you pull on the accelerator cable with the engine off, but I'm not real familiar with Carter carbs. Even a single plane intake would probably run rough, as I doubt only one primary could feed enough fuel to run all 8 cylinders. Also look for a vacuum leak, it would have to be a big one. As for checking the timing, you pretty much have to pull the cover, but I would rule everything else out first, as it is almost impossible to get it sealed back up, and not leak. Good Luck
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 07-19-2003, 05:24 PM   #10
cableguy0
are you sure your distributor isnt off a tooth its almost impossible for a brand new chain to jump a tooth unless you installed it wrong. to me it sounds like your a tooth off
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-19-2003, 06:07 PM   #11
bigjimzlll
bigjimzlll's Avatar
VACUUM leak
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-19-2003, 06:11 PM   #12
68 Stepside
huh?
68 Stepside's Avatar
I agree with bigjim. The 79 F100 out back is the same EXACT way....because I tried to reuse the base to manifold gasket (yes, I'm that cheap, it's a woods truck). Use an unlit propane torch around the intake, and see if the RPM's increase. If they do....you've found your leak.
Good luck, keep us posted.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-20-2003, 09:53 AM   #13
jef5150
Inline 69
jef5150's Avatar
OOPS/EDITED
starting fluid will give the same result,the rpm will rise if theres a leak..........
Old 07-20-2003, 10:08 AM   #14
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
How do you use the propane torch, I have heard that one yet. But I guess I haven't that much yet. Yesterday I saw the saying since "Christ was a Corporal" and thought that was new. I found out otherwise.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 07-20-2003, 11:33 AM   #15
bigjimzlll
bigjimzlll's Avatar
start the engine...turn the gas on, on the propane torch. do not light the tourch...point the nozzle of the flowing torch at the base of the carb..all the way around the bottom...if the engine smooths out..that is where the leak is
Anderson,CA
Old 07-20-2003, 07:30 PM   #16
Kman
Thanks for the input guys.
Wouldn't you be able to adjust dist to compensate for one tooth out?
The fuel problem is the amount of fuel flowing through the two venturi of the primarys one side has no fuel at idle and only a little at higher rpm.
The accelorator pump is fine, two streams of fuel
The timing chain being off a tooth would of happened when I assembled the engine lol.
I am going to work on it tommorow and will check out your suggestions.... I'll keep you posted.....
Kman
Old 07-20-2003, 07:40 PM   #17
jef5150
Inline 69
jef5150's Avatar
total rebuild?.......did you put a new timimg chain & gears on?.....did you line up the 2 dots on the timing gears when you put on the new chain on???
Old 07-20-2003, 07:47 PM   #18
jef5150
Inline 69
jef5150's Avatar
one last thing,,,,,,,,you didnt put the old timing chain and gears on your NEW REBUILD did you??/,,,just asking
Old 07-20-2003, 08:43 PM   #19
Kman
I double checked the marks on gears but something could have moved and yes I used the old chain and gear..I know I know it should of been changed but it was a very low dollar (make it work ) job for a friend
thanks
kman
Old 07-20-2003, 08:54 PM   #20
jef5150
Inline 69
jef5150's Avatar
old gears????????????????????????????????
thats probably your problem,,,,,new gears and chain are like what,, $40.00????????
Old 07-20-2003, 09:02 PM   #21
jef5150
Inline 69
jef5150's Avatar
you could try moving the spark plug wires clockwise 1 position,,,,,see if it helps,,,,then try the other direction,,,,,,,i think even if you pull and move the distributor 1 gear that would be too much,,,,,,butt you can try .....jeff
Old 07-20-2003, 09:07 PM   #22
Kman
I have a list of things to try first
Thanks for the help
kman
Old 07-20-2003, 09:12 PM   #23
bigjimzlll
bigjimzlll's Avatar
a faulty timing chain..or..mis aligned timing set will effect valve timing. its almost impossable for a timing set to skip a tooth..not enuff room. If the set is worn out,really worn out, you would of noticed when you installed it. Check all of the easy things first. Good luck
Anderson,CA
