Old 01-15-2014, 10:29 PM   #1
Cody Sanchez
Headlights
I am having issues with the headlights not turning off. I have to unplug from headlamp bulb to turn off. Any one know how to fix or make any kind of suggestion.
Cody Sanchez is offline   Reply With Quote
Old 01-15-2014, 10:34 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Headlights
Is it stock or do you have a relay circuit? If its stock you may need to check your headlight switch on the dash. If its gone bad change it out.
Year, make. and model info would help.
Old 01-15-2014, 10:38 PM   #3
Cody Sanchez
Re: Headlights
1972 Chevy c10. Is there a way I can test headlight switch???
Old 01-16-2014, 01:13 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Headlights
Pull the connector off the dimmer switch and check for 12 volts on the blue wire with the headlight switch on. Then shut the switch off and check for zero volts on the blue wire. If you get those readings then the switch is good.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
