Old 01-16-2014, 12:14 PM   #1
dave666693
dave666693's Avatar
Military style Hummer wheels
has anyone ran these on their rig that aren't recentered? I have a 70 Blazer with 3/4 ton axles and am wonderong if they will clear.
Oics would be great. Thanks
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 01-16-2014, 04:14 PM   #2
joe231
joe231's Avatar
Re: Military style Hummer wheels
They will hit the knuckle where the tie rod mounts.
Either recenter them, run spacers (2" should do, measure to make sure), or swap in some DRW one ton axles.
CHEVY ONLY
Old 01-16-2014, 05:27 PM   #3
jjzepplin
jjzepplin's Avatar
What's DRW?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-16-2014, 07:38 PM   #4
joe231
joe231's Avatar
Dual rear wheel
CHEVY ONLY
Old 01-16-2014, 08:10 PM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Meh, I am not a fan of the Hummer wheel trend that has been going around as of late. Heavy wheels with horrible offset that require $$$ adapters to make them fit. Not worth the hassle in my opinion.
DirtyLarry is offline   Reply With Quote
Old 01-16-2014, 08:30 PM   #6
joe231
joe231's Avatar
$100 for spacers
$400 (or less) for wheels and PVC inserts.
They are heavy but they are nice for a trail rig.
And I already have a set of 4:56 geared DRW one tons.
I picked up a set of 12 bolts with 37 inch radials for $50 then spent another $125 on new nuts and valve stems. They also have the flat rubber inserts (not run flats)
Then my son picked up a set of 8 bolts with the biased ply 36's for just under $300, and bought new 2" spacers for $100. Hard to beat those prices.
CHEVY ONLY
Old 01-16-2014, 08:45 PM   #7
dave666693
dave666693's Avatar
I can get the wheels real cheap that need to be recentered. I don't want to run spacers. You can buy the centers and do it yourself or have it done. Still pretty reasonable if you want to air down for off road. I was just curious if you could get by without recentering. Now I know. Thanks.
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 01-17-2014, 07:25 AM   #8
andrewmp6
Look at http://www.rockmonsterwheels.com/ they are the same style beadlock but better looking and a 17.Or a totally different beadlock http://www.badwheelsinc.com/store/
andrewmp6 is offline   Reply With Quote
Old 01-21-2014, 09:12 PM   #9
obijuan
im pretty sure they fit on a stock d44. it will suck the tires way under the fenders and look ridiculous. get 2.5 spacers for the front and 3" spacers for the rear and it will look presentable. and you get a very durable and strong double beadlock for rock crawling.
if youre not utilizing the beadlock, i think its a waste of time to get them to fit.
obijuan is offline   Reply With Quote
Old 01-21-2014, 11:43 PM   #10
joe231
joe231's Avatar
I know for a fact they hit the knuckle on a Dana 60.
I dunno why anyone would want to run them on a 10 bolt or a Dana 44
CHEVY ONLY
