01-16-2014, 01:02 PM | #1 |
help...Went to start her up and nothing!
I went out a little while ago to get her started up and running and I get nothing. I have lights but I get no crank. I keep it on a charger when sitting so I'm thinking starter? I'm no mechanic by any means so I figured I'd get my answer here. I ran her less than a week ago and it was a slow start up but I was thinking because it is cold out that's why it was slow. Thanks in advance.
01-16-2014, 01:30 PM | #2 |
Re: help...Went to start her up and nothing!
Could be just the starter relay. Can you jump the starter posts to get it to crank.
Other posibility is ignition switch or a brok/loose wire
01-16-2014, 01:38 PM | #3 |
I really don't have any access underneath the truck. Where would the starter relay be located. Maybe i can check that
01-16-2014, 02:09 PM | #4 |
I would first start at the battery. Check all of your cables and load test the battery. Then work towards the starter. You can have someone turn the key to the start position while you check to see if your getting signal to the starter solenoid? If you are getting power to the starter solenoid your relay should be good.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
