Old 01-16-2014, 10:24 PM   #1
erikoj
16" 6 lug factory rims ? Question
Anyone heard of an optional 16" factory wheel for a c10 or k10 that was offered by gm?? If so, how wide were these rims 5.5" or 6" ?? Or other? I have been told that larger rims were a factory option. I have seen some before but maybe they were an older vintage that happen to fit thanks erik
erikoj is offline   Reply With Quote
Old 01-16-2014, 11:19 PM   #2
junkyard junky
Re: 16" 6 lug factory rims ? Question
I don't know if this may help you or not.
http://www.summitracing.com/parts/wv...0604/overview/
junkyard junky is offline   Reply With Quote
Old 01-17-2014, 12:14 AM   #3
60-66
60-66's Avatar
What year rims ? These are the early 16x5 3 clip rims used up to 1963. These were replaced by the "nub" style that are also 16x5 used from 1964-1970. These were offered on C10 and K10.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-22-2014, 10:33 PM   #4
murphy98
murphy98's Avatar
My '62 came with these 16x5 6 lug with the 3 clips to hold the hubcaps. As far as I know they are factory wheels.
murphy98 is offline   Reply With Quote
Old 10-12-2014, 06:32 PM   #5
american revolution
american revolution's Avatar
What kind of caps will for on these type of rims?
american revolution is offline   Reply With Quote
Old 10-12-2014, 07:36 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
7 5/8" ID for the hubcaps for 15 16 & 17.5" 6 stud wheels with clips.
Old 10-12-2014, 07:50 PM   #7
murphy98
murphy98's Avatar
These are the ones I went with on my rims, not correct for '62 but I love the look! Think they are '55-'59 hubcaps. They were also correct for '60 I believe but smooth, no ribs.
Old 10-12-2014, 09:09 PM   #8
AcampoDave
AcampoDave's Avatar
My first ever c-10 had 3 piece rims. 6 lug 16 or16.5". That was a long time ago so I dont remember for sure. What I do remember is the truck was a 61 and the tire shop wanted nothing to do with them.
AcampoDave is offline   Reply With Quote
Old 10-13-2014, 02:48 AM   #9
american revolution
does these rims clear front disc brake conversion? picked up a set of these
Old 10-13-2014, 08:17 AM   #10
ncoonen
ncoonen's Avatar
Like these 16" from my '65 c30? I haven't seen these in 6-lug style before. No need to be afraid of these as long as you clean them up well and assemble them correctly. Finding a shop that has even seen one before is a trick unless you are way out in the country. The good news is that they are pretty easy to DIY. Just be sure that you wrap the wheel/tire with a stout chain before airing them up just in case the lock ring isn't seated just right.
...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N
ncoonen is offline   Reply With Quote
Old 10-13-2014, 11:48 AM   #11
Old Truck Man
Old Truck Man's Avatar
I really like the three piece rims. Ive got a set of 8 lug 15 in three piece rims. I would like to find a set of 16 in 6 lug two or three piece rims. you can mount a really heavy tire without stretching the beads. I have been fixing split rims for more than 40 years. you need to be careful when fixing them. and if they are not on good condition you scrap them.
Old Truck Man is offline   Reply With Quote
Old 10-13-2014, 12:21 PM   #12
ncoonen
ncoonen's Avatar
The old 3-piece wheels have the right look for a '60s work truck when you mount up a tall narrow tire. But finding the right tires is increasingly hard. STA is pretty much the last man standing in this market.
Old 10-13-2014, 12:33 PM   #13
Old Truck Man
I want to use then on my trailers. I can get 15 and 16 inch 14 ply lowboy tires that hold 80 pounds of air. most of my trailers have the chev 6 lug pattern hubs. My tilt top trailer has heavy 14 ply bias lowboy tires mounted on 15 inch split rims. I found a source for a 6 bolt hub bearings ect. that will fit on a house trailer axle. Ive replaced the 14.5 tires Dayton rims & hubs. if the 14.5 tires state for mobile home use only their illegal to use on a utility trailer.
Old 10-20-2014, 09:28 PM   #14
american revolution
are these worth restoring...3 seam to match...1 of them looks different...
16x5 wheels
Old 10-20-2014, 10:01 PM   #15
perro13
perro13's Avatar
16x5 wheels
they look worth restoring, lug nut hole look good. Those look like 40's-50's style 16" rims
perro13 is offline   Reply With Quote
