Old 01-17-2014, 12:06 AM   #1
cigar-
cigar-'s Avatar
starter motor
I have gotten to the point of installing the starter motor on the new engine. the one I bought is from Napa. When I look up the part number they sold me it says the starter is for an automatic transmission as well as a manual transmission.
The problem is that the snout won't fit into tho opening on the bell housing. Has anyone else run into this situation? Any answers? Please help!!
cigar- is offline   Reply With Quote
Old 01-17-2014, 12:19 AM   #2
cigar-
cigar-'s Avatar
Re: starter motor
BTW.....I have a three speed bell housing and a new crate Chevrolet 350 engine in the truck.
Old 01-17-2014, 12:25 AM   #3
Lattimer
Lattimer's Avatar
Re: starter motor
Are you mounting to the bellhousing or to the block? Which flywheel do you have? There are 2 different tooth counts, which require 2 different starters.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-17-2014, 12:31 AM   #4
cigar-
cigar-'s Avatar
Re: starter motor
I am trying to mount to the block. The newer engines from Chevy allow either the straight or staggered bolts starter to go in. The flywheel is a 168 tooth one.
The motor goes up and in only about 75 % of the way. It's as if the snout is too big for the opening.
Old 01-17-2014, 12:39 AM   #5
Lattimer
Lattimer's Avatar
Re: starter motor
Thats a weird one. I have the original bell from a 3-speed in my truck, and I currently have a high torque mini starter that mounted up perfectly. Previously I had the bellhousing mounted starter and that was easy also.
Is it possible they gave you the wrong part? I've had that happen before---right box wrong part.
Shawn
Old 01-17-2014, 12:44 AM   #6
cigar-
cigar-'s Avatar
Re: starter motor
It's possible I guess. I looked at the Napa website at all of the starters they list for that truck. The ones they show for manual transmissions look like the snout is smaller and they bolt to the bell housing.
I am trying to go back to a somewhat stock configuration. This truck was originally an inline six (250 ci) and was converted to a 350. When I bought the truck it had a smaller than stock starter in it. I am going to try and slide that one into place tonight and will compare the smaller one to the stock one. I am getting the feeling the snout is smaller on the aftermarket unit.
If I have to I'm going back to Napa in the morning for a refund or exchange.
Old 01-17-2014, 02:43 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Re: starter motor
All of the 3 speed trucks i have had mounted the starter to the bellhousing, not the block. The manual trans starters ar ediffsrent from auto starters. The manual rans starterea have a smaller snout to fit in the hole.
I guess I dont follow why you are replacing the starter. Is the one you have giving you trouble? Personally, i subscribe to the "if it aint broke, dont fix it" lifestyle.
WIDESIDE72 is offline   Reply With Quote
Old 01-17-2014, 03:01 AM   #8
cigar-
cigar-'s Avatar
Re: starter motor
WIDESIDE72
The starter that came on the truck is an aftermarket one that was installed by a previous owner. He cut all kinds of wires to make it work and in doing so, made that amp gauge inoperative. I want to go back to using the stock gauges so the wiring needs too be stock.
I'll simply buy the correct starter motor...
Thank you for the input!
Old 01-17-2014, 12:43 PM   #9
Wrenchbender Ret
Re: starter motor
If it has the cast iron bell housing with the opening at the bottom you must use the starter that bolts to the bell housing.
Wrenchbender Ret is offline   Reply With Quote
Old 01-17-2014, 04:50 PM   #10
67chevemall
67chevemall's Avatar
Re: starter motor
Bell housing mount for 100 Bob.
Get the mini CVI high torquer you will never regret it
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
