01-17-2014, 11:25 AM | #1 |
Temp Gauge Options
I've done some searching and I'm more confused than I was before. I just feel as though the truck is running hot and I hate not truly knowing.
'71 w/ factory 250l6 and 3OTT. It has the most bare bones gauge cluster. What's the best set up/way to add a temp gauge? I don't care if it's in the cluster and would even be OK mounted to the steering column so it could always be removed if I wanted to. Thanks for the help. |
01-17-2014, 12:57 PM | #2 |
Re: Temp Gauge Options
I have same stock gauge in my 68 GMC, you can get a three gauge set up at most auto parts stores. Engine Temp, oil pressure and amp or volt gauge . I mounted mine under dash below radio. It looks stupid but tells you a lot more then the stock idiot gauge from the factory .....
71 C-20 07 Magnum RT AWD |
01-17-2014, 01:31 PM | #3 |
Just to be clear you have the three hole cluster with the center warning lamps right?
If so adding a gauge cluster or a gauge and tach cluster is pretty straight forward. Once you have a cluster the wire harness connector/plug needs to be repinned to match the gauge cluster correctly. A gauge temp sender needs to replace the engine's thermal switch. Then the oil pressure hard line running from the engine to the cluster is added. If you are adding a tach it has a seperate harness as well. Tbone1964 reconditions clusters but shoulld be able to fix you up with a tested ready to go stock cluster assembly. http://67-72chevytrucks.com/vboard/s...d.php?t=604141 Or you can just hang some add on gauges that are electric or mechanical.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-17-2014, 01:40 PM | #4 | |
Cluster King
Let me know if I can help you. I can offer you many different options to get you a cluster or modify your existing cluster to fit your specific needs. Thank you, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-17-2014, 04:26 PM | #5 | |
01-17-2014, 04:27 PM | #6 | |
Thanks guys! |
01-18-2014, 07:57 PM | #7 |
My cluster has the temp gauge but it isn't hooked up to anything. Im assuming there is a thermostat that plugs into the block. Can yall tell me what part im looking for and where I can find one?
01-18-2014, 10:32 PM | #8 | |
http://gmcpauls.com/Tech%2520Tips1.htm Last edited by FirstOwner69; 01-18-2014 at 10:44 PM. |
01-18-2014, 10:39 PM | #9 | |
http://i717.photobucket.com/albums/w...pse169ce2b.jpg |
01-19-2014, 12:13 PM | #10 |
Thanks FirstOwner, that doesn't seem like it will be too difficult.
