Old 01-17-2014, 03:07 PM   #1
Bowed
Jammed ignition cylinder lock
2000 Silverado Z71 auto all power
The ignition cylinder/lock was starting to catch and once in a while would jamb a little . I removed the lock and had it rebuilt at a locksmith . I reinstalled the rebuilt lock and it was turning smooth with no jambs at all . last night I shut down the truck , placed the shift lever in park position , wiggled the steering wheel to check it was in locked position and then turned the key on/off 3 times to make sure everything was OK and it was still working perfect . This morning I got in ( touched absolutely nothing ) and the key will not turn no matter what I do . I don't understand what could do that . Again I touched nothing except locking the doors . I have tried moving the steering wheel all ways , pulling the shift lever while stepping on the brake , tapping the key and everything else and it won't turn . Does someone have an idea what is jambing this up . Is there any electrical locking function when you turn the key off ? Thanks
Bowed is offline   Reply With Quote
Old 01-17-2014, 04:04 PM   #2
Bowed
Re: Jammed ignition cylinder lock
So I just went out again and when I put the key in , it turned and started easy as pie . ????? Also the locksmith made new keys for the lock rebuild , so the keys are tuned to the rebuilt lock .
Old 09-28-2014, 09:05 PM   #3
William Dingh
William Dingh's Avatar
Better late than never Dept:
I'm thinking that the same thing kept happening to me.
The key would only turn when AAA road guy would turn it.:waah
You have to remove the ignition cylinder to fix the problem.
These photos show what I found to be my problem.
Name:  ignition cylinder pin cropped.jpg
1st pic. is of ignition cylinder showing a pin that I've pushed back out of the slot so you can see it.
Name:  ignition cylinder pin slot cropped.jpg
2nd pic. is of the ignition cylinder with the "slot" the pin goes into to lock the steering column.
I made that incline smoother with a Dremel carbon polishing attachment and then some graphite powder.
William Dingh is offline   Reply With Quote
